Where does this 460 vacumm fitting go
Old Mar 17, 2012 | 01:04 PM
Ford59galaxie's Avatar
Ford59galaxie
I did work on my 460 and I plugged the holes and can't remember where this fitting goes. I am holding the vacumm fitting in my hand and i believe it goes in the hole right next to it. I am unsure though because this hole is wet and smells like antifreeze. Would I be able to just put a plug in this hole and run 1 single vacumm line from the distributor to the carburetor?
Old Mar 17, 2012 | 01:06 PM
Ford59galaxie
Old Mar 17, 2012 | 02:16 PM
critterf1's Avatar
critterf1
That's where it goes. It's a ported vacuum switch.
Old Mar 17, 2012 | 02:26 PM
beetle's Avatar
beetle
If you can't thread it there due to interference with the dist cap, then just remove the plug on thermo housing and put it there, either place is the same.
Old Mar 18, 2012 | 01:16 AM
Ford59galaxie
Ok thanks guys! Got it together in that hole
F460bigbore
20
Aug 12, 2018 09:06 AM
jbas
Jan 29, 2018 10:11 PM
LittleBlue79
Feb 12, 2017 02:26 PM
Highboy74
Apr 18, 2015 03:32 PM
Galm_2
24
Aug 14, 2011 09:34 PM
