03 Expedition shift indicator
Old Mar 16, 2012 | 05:44 PM
wynelocked's Avatar
wynelocked
I did search around for some info about this.I broke the one on a 03 Expedition.The part that has the small wire going thru it.Looks like a threaded piece that screws into a thrumb type screw for adjust it.
Any info would be helpful.
Also...Ford lied...hahahaha
The fuse panel is NOT where the manual says.I still have'nt found it.
Problem that started all this is a "door ajar" lite that won't go off...yet there's no door ajar.
I killed the lite!
Old Mar 17, 2012 | 03:51 AM
alloro's Avatar
alloro
You can either replace the part or do as some others have and use a wire tie to pull the cable just enough to line-up the shift indicator.
Check the passenger kick panel for the fuse box.
The door switches are built into the door latches. Spray inside the latch liberally with WD-40 to free up the switch. Don't forget to do the rear hatch and glass latches.
outlawkyote
Jul 14, 2011 10:23 AM
TCinNH
1997 - 2003 F150
Mar 12, 2006 09:24 PM
CharlestonSC
Aerostar
Jul 6, 2005 12:46 PM
gtarp
1983 - 2012 Ranger & B-Series
Nov 30, 2004 08:05 AM
