a little help with these codes?
this is the engine one test
21. Engine Coolant
Temperature (ECT) sensor
signal voltage: out of range
(Key On Engine Off Self-
Test), not at normal
operating temperature
(Engine Run Self-Test) or
loss of signal (during
normal engine operation).
or,
Electronic Distributorless
Ignition System (EDIS) fault
– problems with Crankshaft
Position Sensor (CPS)
circuit.
44.
Problems in Thermactor Air
Control system.
33.
EGR Valve Position (EVP)
sensor or Pressure
Feedback EGR (PFE)
sensor indicates EGR valve
is not opening.
or,
sensor or Pressure
Feedback EGR (PFE)
not seated (closed) properly
74.Brake ON/OFF (BOO)
switch action not detected
during Dynamic Response
portion
of Engine Run Self-Test.
soo!! the last code was cuasing my OD botton to swith on and of when i touch the brake!! i have another post about that problem
But Can anyone tellme what are they what are they causing? these codes?
Adaptive limit means the computer is trimming the fuel mixture based on the O2 sensor feedback and has reached the limit to how much more fuel or less fuel the engine needs, but the mixture is still wrong. It could be an O2 sensor, or it could be a vacuum leak or a fuel leak, or possibly even a misfire. These OBD-I codes are not as specific as the OBD-II codes are, so diagnosing the actual cause of the problem on these trucks is a little more complex.
the boo switch i didnt press the brake after i goosed the trottle and yeah the 21 code becuase i didnt let it go to operating temp before doing the test soo code
33 and code 85 and 86 those are the codes. i dont understand about code 85 and 86 any tips?
