Sponsored by: Real Truck
2005 4x4 problems
Old Mar 16, 2012 | 10:46 AM
sansinga13's Avatar
sansinga13
Is the solenoid the same thing as the vacuum pump? Or are they 2 different parts?
Old Mar 16, 2012 | 10:52 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Different parts. If you look at that pic in that link I gave you, you will see the vacuum pump next to that football looking holding tank. lol
EDIT: When you turn the key on, you will hear the fuel pump come on also. The fuel pump is under the cabs drivers side. Kind of right under the front door on the frame rail. Is this what you heard???
sansinga13's Avatar
sansinga13
Ok I followed one side and found a bunch of liquid on a part of the line.
Old Mar 16, 2012 | 10:56 AM
miller_feed
Humm, what type of fluid is it? Which side?
Old Mar 16, 2012 | 11:00 AM
sansinga13's Avatar
sansinga13
Passenger.I'm thinking that its the a/c, but could it mess up something electrical? And also, on the passenger side there is a ring that is out of place. Can I post pictures?
Old Mar 16, 2012 | 11:09 AM
miller_feed
The vacuum lines going to the hubs don't go under the ac. That is maybe the line going to the blend door. The lines I'm talking about come from the solenoid to the front hubs.
It would help if you could post pics. I use photobucket to post some of my pics.
Old Mar 16, 2012 | 11:17 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
At this point you need to check the truck with all 4 tires off the ground
Your hubs are working
Your shift motor is working
So unless your t-case is broken, I'm thinking you are actually in 4x4
Are you positive the wheels werent turning? Remember that only 1 tire is going to spin up front....the one with least traction.
Go find some dirt. Manaully lock the hubs. Shift into 4x4 low. Goose the throttle and cut the wheel over hard. Get out and check your tire spin marks.
Old Mar 16, 2012 | 11:38 AM
sansinga13's Avatar
sansinga13
Ok if the vacuum pump was broken wouldn't I still be able to turn the hubs and have 4x4?
Old Mar 16, 2012 | 11:43 AM
sansinga13's Avatar
sansinga13
Thanks for all of your help!
Old Mar 16, 2012 | 11:46 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
As long as the t-case shift motor works, you will still have 4x4
Hubs fail: manually lock them
It's annoying if the vacuum solenoid fails, or some other issue. But that won't kill the 4x4. It just makes you get out and do it old style
Old Mar 16, 2012 | 12:17 PM
miller_feed
Yes, your hubs should still lock without vacuum when doing them by hand.
Hang in here, we will figure this out.
williams242
Mar 26, 2019 07:40 PM
Bobby Mathers
Jan 6, 2018 12:12 PM
IHpuller450
6.4L Power Stroke Diesel
Jun 16, 2015 08:56 AM
Dutter 2
1997 - 2003 F150
Dec 9, 2013 10:55 AM
NCPirate
Jan 22, 2012 09:58 PM
