96 dual tank switch question
Old Mar 15, 2012 | 05:55 PM
trapperjack's Avatar
trapperjack
The p.o. said both tanks work fine, but said he hadn't used the rear tank in years. Can I turn the key partway, flip the switch, and see what the fuel level is without actually changing anything? I just want to see how much gas is in there. If it's close to E I'll just put some in and run it. If it's half full of old gas, I want to drain it.
Thanks.
Old Mar 15, 2012 | 06:20 PM
882tank's Avatar
882tank
You can. In an "attempt" to keep as much old fuel out of the system, build your fuel pressure with front tank before you switch it. Definitely drain the tank of old gas.
Old Mar 15, 2012 | 06:33 PM
trapperjack
I just tried it. Rear tank shows just under 1/4 tank. Wonder if I fill it up and go, if it will dilute the old stuff enough? Don't want to put seafoam or cleaner in it, allready did the front tank. From reading on here, looks like it's next to impossible to drain the tanks from the filler neck. Maybe if I put some premium in it one time?
Thoughts?
And thanks.
Old Mar 15, 2012 | 06:45 PM
BigBlueOx's Avatar
BigBlueOx
Will it run on the rear tank for an extended amount of time? If so then I'd do the "fill it with super trick" lol
Old Mar 15, 2012 | 07:01 PM
BrianDguy's Avatar
BrianDguy
This would be what I would do if it were me.
Old Mar 15, 2012 | 09:57 PM
trapperjack
Had to make a quick 60 mile round trip this evening. Put some liquid gold (premium) in the rear tank, got up to 70 mph and flipped the switch. Ran like a scalded dog the whole way. Thanks for backing me up on what I was probably going to do anyway.
KNELSONCONST
74
Jan 23, 2021 02:02 PM
ToddGatman
Jul 2, 2013 03:43 PM
grizz 454
Feb 9, 2011 07:32 PM
Marty86
Oct 21, 2006 05:26 AM
disco
Feb 11, 2004 07:00 AM
