EOT and ECT
Old Mar 15, 2012 | 05:50 PM
asmyth18's Avatar
asmyth18
EOT and ECT
I see alot on here about EOC and ECTs. This may sound crazy to some of you but how are you getting your temps. Are gauges and sensors installed. New owner of my first diesel so this is somewhat new to me.
Old Mar 15, 2012 | 06:18 PM
VQT's Avatar
VQT
A Scangage II can provide these and other information for your truck. Cost about $160 from any auto parts store. Check Autozone or ebay
Old Mar 15, 2012 | 06:27 PM
Bigdaddybus's Avatar
Bigdaddybus
i use an SCT livewire for tuning and monitoring eot, tft, and ect while towing
Old Mar 15, 2012 | 06:32 PM
wulfman's Avatar
wulfman
X2 for the dollars you can't beat it does everything you need checked on your truck.
Old Mar 15, 2012 | 06:41 PM
critterf1's Avatar
critterf1
I have an OTC but I use it on everything from these trucks to VW's.
Old Mar 15, 2012 | 06:45 PM
T diesel's Avatar
T diesel
Old Mar 15, 2012 | 07:40 PM
1BadHabit's Avatar
1BadHabit
Just to further the explanation.....
The truck already has sensors for the EOT and ECT. The truck's PCM monitors these readings as part of it's normal operation.
What the ScanGaugeII and SCT Livewire (as well as the Edge CTS) do is plug into the truck's OBDII port and let you also see the information that's already being delivered.
Old Mar 15, 2012 | 08:27 PM
GreenPSD's Avatar
GreenPSD
Just to clarify, the Scanguage II out of the box does not measure EOT and alot of other parameters. It must be programmed with what they call Xguage codes. Some of the codes can be found on the Scanguage website and many others can be found on this forum. Do a search of scanguage II codes or xgauge codes.
Old Mar 16, 2012 | 03:15 AM
Dieselpop's Avatar
Dieselpop
the Edge Insight CTS is great tool, and with the expandable probe if you want to add more to it down the line you can, plus run 8 things at one time. Most are Free shipping over $50 it is plug and play
http://www.xtremediesel.com/edgeproductInsightCSCTS.aspx
Things you can add down the line like turbo timer & back up Monitor & fuel pressure
The Edge accessory system (EAS) was created with future expandability in mind Product Code: EDG98603
http://www.toyhauleradventures.com/2011/04/edge-products-cts-update-turbo-timer-install/ Product Code: EDG98604
http://www.toyhauleradventures.com/2011/02/insight-cts-monitor-by-edge-products/
Ford Powerstroke 6.0L fuel pressure monitor and low pressure fix. | Toy Hauler Adventures
Fuel pressure is also important because pressure under 45lbs at WOT kills injectors so the new fuel reg kit is needed (blue spring) to up the fuel pressure, mine after the install 58lbs WOT and 62-64lbs at idle.
This is what i got for the fuel pressure gauge, it goes into the test port, this is a cool set up gets the sender away from the heat and viberation of the motor.
http://dan.prxy.org/Truck/6L_bible_html/html/Page_030.html
http://shop.strictlydiesel.com/store.php/products/60L_FP_Adapter
Column Pod
http://shop.strictlydiesel.com/store.php/products/15010
Autometer Fuel Pressure gauge---Bottom Left (This matches my Dash gauges)
Phantom II Gauges
pop
Old Mar 16, 2012 | 07:54 AM
Cowboy65's Avatar
Cowboy65
I'll throw in a plug for the DashDAQ which I've been using for while with good success. Not only can you monitor the EOT and ECT individually but you can also do the math to display the delta and alarm if any monitored parameter is out of range.
Old Mar 16, 2012 | 08:26 AM
AZwhite350's Avatar
AZwhite350
if you have a smartphone, you can use a Bluetooth OBDII adaptor from e-bay and download the Torque app. You can add an app for Ford vehicles for free as well. Total cost is about $35 (assuming you have the smartphone).
Old Mar 16, 2012 | 09:22 AM
asmyth18's Avatar
asmyth18
Can't find the torque app. All the information has been very helpful thanks
Old Mar 16, 2012 | 10:12 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Isspro EV2 2" gauges are awesome. For stuff that the ODBII connector can read they aren't really necessary, but for some things (fuel press, mechanical boost, pyro, diff temps) they're cheaper than the cost of the expandable wiring for the Edge CTS.
Riffraff Diesel Performance Parts: - Black Face/ Red Pointer/ Black Bezel
Old Mar 16, 2012 | 10:19 AM
asmyth18's Avatar
asmyth18
iPhone app
The iPhone app is called Rev and Torque is android. Not a lot of good reviews for the Rev app. Again thanks for all the help
tyler2004
19
Jul 29, 2009 06:06 PM
23larry24
37
Jun 24, 2008 08:38 AM
dakota joe
Jun 19, 2006 06:47 PM
mcisneros411
Dec 27, 2005 07:00 PM
Ghostrider304
Jan 25, 2002 05:56 PM
