Oil
Old Mar 15, 2012 | 04:05 PM
diablodude64's Avatar
diablodude64
Oil
I've recently got my truck back on the road, and it's been running great. However this morning, it started having a loud lifter tick, so I checked the oil and it showed about 1mm of oil on the dipstick. I just changed the oil, and it isn't burning oil, but near the crossover pipe you can see oil on the bottom of the block and on the pipe itself.
Could this be a main seal? Would all 12 quarts be gone like that?
Thanks, Kyle
Truck is a 1987 f250 with the 6.9
Old Mar 15, 2012 | 04:51 PM
Aune163rd's Avatar
Aune163rd
Not all 11 quarts of oil are gone, if its reading that low on the dipstick, its lost about 3 quarts, i would check the condition of your CDR valve...its a can looking thing at the back of the intake manifold. Will find a picture and post it.
Old Mar 15, 2012 | 06:22 PM
diablodude64
The cdc valve is clean as of about a month ago....
Old Mar 16, 2012 | 11:12 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Check:
Your rocker covers.
Oil pressure sender.
Valley pan.
Those are typical oil leak locations, unfortunately so are the main seals, front and rear.
-Enjoy
fh : )_~
Old Mar 18, 2012 | 11:56 AM
Fuelhog 5212's Avatar
Fuelhog 5212
If a rear main seal were leaking (mine is a '93 turbo 7.3 idi) would oil be xferring into the transmission housing? If so, maybe that is where mine has been going. Tranny is an E4OD.
Old Mar 18, 2012 | 12:16 PM
Phy's Avatar
Phy
There's a drain on the bottom of the access cover on the bottom of the bellhousing, but if that was plugged up...
Old Mar 18, 2012 | 01:36 PM
ford trans tech's Avatar
ford trans tech
the wrong type of oil will induce high usage also
especially an oil that doe not have teh required anti foaming agents
with oil at the rear i would start by checking the oil sending unit and the valley pan first
bigsteve1969
19
Aug 23, 2008 05:51 PM
pdqtimetrialer
Mar 27, 2008 12:33 PM
ssanto
Oil & Lubrication
20
Feb 9, 2008 11:28 PM
jclj2003
Jan 11, 2004 08:27 AM
wickware
Nov 6, 2003 12:50 PM
