looking for shocks.....
Old Mar 15, 2012 | 11:29 AM
thebandit343's Avatar
thebandit343
I have a 96 f250 7.3l diesel that is an extended cab longbed. i am in need of some new shocks and was wondering what people on here think is the best shocks out there for a decent price? I don't really want to break the bank but would like a quality shock. What is your opinion?
Old Mar 15, 2012 | 11:39 AM
Beechkid's Avatar
Beechkid
Shock Recommendations IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone that are 100% steel belted or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG that are a mix of steel & nylon belted or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
Old Mar 15, 2012 | 03:01 PM
mjonesjr's Avatar
mjonesjr
Bilstein is the best shock to use on your truck IMO. I tried a couple other brands and took them all back before I got my Bilsteins. I will not run any other shock on any vehicle.
jp4lsu
Jun 27, 2013 02:52 PM
casados303
6.4L Power Stroke Diesel
Sep 10, 2012 01:46 PM
RedBoat
6.7L Power Stroke Diesel
32
Apr 2, 2012 02:19 PM
Genesis
Jun 9, 2009 02:15 PM
wreckinball
May 27, 2009 12:06 PM
