That start up tone..........
Old Mar 15, 2012 | 11:10 AM
jack_pine's Avatar
jack_pine
Obviously not critical but drives me nuts (wife says that is a short ride )
On my '12 when you turn the key to start the truck in plays that three tone "jingle' a few times. (have sync/nav)
Can that be turned off. Better yet it would be cool if you could change it to like the first part of "Back in Black" (Even though the truck is red).............
Old Mar 15, 2012 | 12:37 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
I need Anchors Away
Old Mar 15, 2012 | 03:20 PM
Brandon Bloomquist's Avatar
Brandon Bloomquist
Is this the three tone one that sort of plays "hey-dumb-***" "hey-dumb-***" "hey-dumb-***" "hey-dumb-***" at you? Or, when the parking brake is engaged, more of a "hey-dumb-***!!" "hey-dumb-***!!" "hey-dumb-***!!" ?
Old Mar 15, 2012 | 04:20 PM
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Talking Ya Got'er
Yepper
Now, make is play Anchors Away!
Old Mar 15, 2012 | 04:27 PM
Averill7's Avatar
Averill7
Try buckling up and releasing the ebrake before cranking the engine. I do this in mine (no nav) with zero chimes.
Old Mar 15, 2012 | 04:46 PM
jack_pine's Avatar
jack_pine
Could do all of that....................Anchors away, maybe.
Thought I may get this response. All good. Am I the only one with is issue?
You all love that tone? If so, be well.
Old Mar 15, 2012 | 04:56 PM
FishingNut's Avatar
FishingNut
Like I love my wife, but she also gets ignored when she is talking...er..chiming
Old Mar 15, 2012 | 05:14 PM
kper05's Avatar
kper05
I call it the do-da-do tone.
If you close all doors and lock the driver seat belt before inserting/turning the key, it will not alert you.
Then pull the park brake before shifting out of park to prevent that alert.
Old Mar 15, 2012 | 05:30 PM
jack_pine's Avatar
jack_pine
Fine, can do that. Just saying your own tune would be way cool......
Old Mar 15, 2012 | 06:56 PM
Brandon150's Avatar
Brandon150
Could get rid of all the chimes with a chip but we won't go there...
Old Mar 15, 2012 | 07:56 PM
jack_pine's Avatar
jack_pine
Ok, got it. Kind of thought this was a fantasy post......but kind if serious.
I really do not like the "tone" but seems like no way out.................
Presume you are all ok with it..All good....
Old Mar 15, 2012 | 08:27 PM
TRENT310's Avatar
TRENT310
Does the seatbelt chime disable procedure outlined in the manual disable the initial seatbelt warning chime? That's what we're talking about aren't we?
Old Mar 15, 2012 | 08:35 PM
kper05's Avatar
kper05
That process only disables the ding (it's a different tone) if your seatbelt isn't locked while in a gear other than [P].
This does not disable the chime when turning the key to on and seat belt unlocked.
That's how my truck behaves at least.
I do have the seatbelt ding disabled.
Old Mar 16, 2012 | 05:19 AM
ruschejj's Avatar
ruschejj
The dings don't bother me. I have disabled the seat belt ding and the door open/key in ding. So all I have left is the key on/door open ding.
I do agree with jack though in that with the tech of today there are simple ways we should be able to customize many aspects of our vehicles without interfering with dot regs. Dings are one, permanent back up sensor disable, and many others.
Old Mar 16, 2012 | 03:09 PM
srkr's Avatar
srkr
I disabled the seat belt chime all together,..the requirement that makes you bucke up. Won't go off till you click it in.
I also cut a wire under the steering column to stop the chiming when the door is open while key is in ignition.
Shane
