Adding second battery, using stock parts.
Old Mar 14, 2012 | 10:36 PM
Bbasso's Avatar
Bbasso
Tomorrow I'm hoping to find all the stock parts to put in a second battery, just like my diesel van had...
Obviously the battery box that hangs off the passenger side rail, the big fat wires that run to the front/main battery.
Anything else I might need that I might not see while at the junk yard?
Such as hidden wires, relays, etc.
thanks for the assistance!
I've had the second battery sitting, just waiting for a purpose lol.
Old Mar 15, 2012 | 12:27 AM
joshofalltrades's Avatar
joshofalltrades
for diesels, the 2 batteries were directly wired together, for many RV applications, they are run through an isolator so you can drain the one battery with RV accessories and still have a full starting battery. its pretty straightforward: mount the battery, have cables made up, and you're good to go
Old Mar 15, 2012 | 09:29 PM
Bbasso's Avatar
Bbasso
the Pull A Part junk yard had 8 econolines... but none had the factory second battery. dammit.
BUT I did find two cool items, pics tomorrow! (daylight needed)
Old Mar 15, 2012 | 09:37 PM
joshofalltrades
maybe you could build your own battery box. in the 80s they put them both up under the hood, but it sounds like your old van was down on the frame rail. either position isn't too hard if you have space, just make it strong and secure, both against vibrations and against theft.
Old Mar 15, 2012 | 11:01 PM
Bbasso's Avatar
Bbasso
while I'm creative...I don't have the tools or space to build.
Old Mar 17, 2012 | 09:25 PM
V10E350's Avatar
V10E350
The prices I'm sure have changed since I got this. This is to add a second battery to the one already on the frame rail of an E350.
Battery Support, PN 4C2Z10769AA. List $145.20
Cover, PN 4C2Z10A687AA. List $65.49
Retainer,PN N808992S301. List $19.50 need 2
Hex nut, PN W701651S60. List $11.70. Need 2
Bolt, PN N605907S440. List $7.15. need 2
USA Part ?, PN N605920S439. List $4.55. need 4
hold down spacer, PN E7TZ10718B. List $6.24.
Spacer, PN 6C2Z10756A. List $12.45
Old Mar 17, 2012 | 09:51 PM
Bbasso's Avatar
Bbasso
thanks!!
just what I needed
Old Mar 26, 2012 | 10:01 AM
Bbasso's Avatar
Bbasso
Hey!
I just spent some time with the girl at the Ford parts counter and we both can't figure out the exact parts I need to get the second battery mounted.
Maybe you could help.
She said that my 2005 could be different then my 2000 which had the second battery so if I order the wrong parts I'm stuck with them. (crap)
here is some paper work she had given me, maybe you could help me figure out what will work and which items I need to order.
As for the wiring, I'll do it myself and for the hardware, I'll source it myself too Unless you think it would be wise to get the nuts/bolts from Ford...
Old Mar 27, 2012 | 06:17 AM
JWA's Avatar
JWA
Hey BB---have you yet contacted Tousley Ford, one of the FTE sponsors? They might be a lot more helpful than the girl at your local stealership. Most times while ordered but new uninstalled parts CAN be returned its not something the dealers look forward to doing--understandably. They might charge a re-stocking fee but I can't see most of the better dealers outright refusing to take something back.
Your project might be VIN specific as the frames could be different--perhaps a bit of digging deeper by an enthusiastic dealer might be more helpful?
Hope this comes together easily for you!
Old Mar 27, 2012 | 07:37 AM
Bbasso's Avatar
Bbasso
A member on a different forum is selling me his spare battery box for a very reasonable price, So I'll start with that one and if it fit/works then I'll have the knowledge to order another for the third battery. From the seller's pictures it looks exactly like the one that was in my 2000 PSD Van. The only thing not included is the bolts and the positive wire, but I will make/get those from local stores.
Now to directly answer your question, No I haven't contacted any of the FTE sponsors, but the girl at the local dealer was enthusiastic about helping me, she loves that I have these projects and probably spent over 40 mins with me... I think she even might like me lol
Old Mar 27, 2012 | 07:59 AM
JWA's Avatar
JWA
Not a thing wrong with that then! Best of luck?
You're on the right track with receiving the spare box, checking how it installs and if something similar will work in your situation. Since you're limited on tools and space a bit of creativity and ingenuity will be your best help then.
You taking any photos of the before, during and after? This might make a good reference for someone else considering the same thing.
xxxsherpa
Jun 26, 2017 02:44 PM
lutarious
Dec 6, 2016 01:27 PM
john fin
Nov 24, 2011 06:11 PM
JoePa2
Oct 21, 2011 11:34 AM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
