Truck weights
Old Mar 14, 2012 | 09:33 PM
Vinford's Avatar
Vinford
Truck weights
Does anyone know if there is somewhere online I can find out what my truck weighs?
1999 F-350 4x4 reg cab dually
2002 F-350 crew cab short box 4x4
Both diesels.
Im having DOT issues.................
Old Mar 14, 2012 | 09:44 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
http://catscale.com/
Other than that, read through the many truck weight threads. Mine comes in at about 7500#. 2002 7.3 CCSB 4x4
Old Mar 14, 2012 | 09:56 PM
Vinford's Avatar
Vinford
Nothing like that scale around here.
Maybe the local landfill site would weigh them?
Old Mar 14, 2012 | 10:00 PM
JT250's Avatar
JT250
Mine is a crew cab 4x4 03 it is 7700 lbs
Old Mar 14, 2012 | 10:04 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Could try the landfill. Mine will weigh any vehicle for $5 but its not a certified scale.
Old Mar 14, 2012 | 10:26 PM
JT250's Avatar
JT250
Our landfill is certified
Old Mar 14, 2012 | 10:32 PM
7.3 Rocket's Avatar
7.3 Rocket
Both diesels.
DOT usually goes off GVW or weight you're registered at not curb weight around here.
Old Mar 14, 2012 | 10:39 PM
bulla's Avatar
bulla
There are tons of variables. Best to just weigh it yourself. For instance, tools, bumpers, wheels and tires.ld bet though that the two trucks in question should be within 500 lbs of each other. Really just a guess but problem 7,500-8,000. Mine is a cc lb dually 4x4 with bigger tires, bumpers, headache rack, and a small box in the bed and it weighs just under 9,500 without me in it. What's dot saying?
Old Mar 14, 2012 | 10:58 PM
Vinford's Avatar
Vinford
I got stopped and told I wasnt licensed right to be towing my car trailer and Bobcat.
They go by the combined weight the way he was explaining it , Im licensed for just over 11,000lbs but my combined unit would weigh out roughly at 16,500 lbs.
Bobcat is 6200 lbs , trailer is approx. 2500lb .
Old Mar 15, 2012 | 12:00 AM
7.3 Rocket's Avatar
7.3 Rocket
Looks like you've got some other stuff on the trailer as well so I'd add an extra 500lbs to your weight but I'd guess the truck at 8250 with about a quarter tank of fuel in it and not much in the cab.
Old Mar 15, 2012 | 05:05 AM
Joe28443's Avatar
Joe28443
Joe28443
I would have guessed that much weight too. You are right DOT goes by GVWR. The license weight covers truck, trailer and load. I weighed a truck like that last week.
Old Mar 15, 2012 | 05:32 AM
japaleno's Avatar
japaleno
Both diesels.
At the top of this Forums page is a tab labeled 'Articles/Specs" under that is a link for "Specifications". There it will give you the weight as it came off the assembly line, but of course you need to add anything that wasn't factory. Good luck.
89F250_7.5
Jun 20, 2017 11:32 AM
kaw753
Mar 15, 2010 09:38 PM
Brown Falcon
23
Jan 16, 2010 12:09 PM
my79f
Jul 15, 2009 01:39 PM
scottie2hottie
Aug 29, 2006 03:04 PM
