`05 torque shift trans leaking
Old Mar 14, 2012 | 07:40 PM
Kahuna's Avatar
Kahuna
I have a bad leak in the trans `05 6.0 torque shift.It`s coming from the rt. rear of the trans up above the pan where i cant get a good look at it.it appears to be just forward of the cooler line.This just happened suddenly yesterday.
Old Mar 14, 2012 | 08:00 PM
wulfman's Avatar
wulfman
Not sure about leak but i would bet on cooler line if its coming from that area. These tranny's seldom have any problems . hopefully Mark the tranny guy will chime in and give you some info.
Old Mar 14, 2012 | 08:13 PM
Kahuna's Avatar
Kahuna
Not the line i can see where the line goes in.
Old Mar 14, 2012 | 09:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Is there a hole in the case? The '05 TorqShift had problems with a snap ring coming out and punching a hole in the case.
Old Mar 14, 2012 | 09:17 PM
Kahuna's Avatar
Kahuna
I sure hope not but From some research ive done I`m thinking that might be the problem.
Old Mar 19, 2012 | 01:29 PM
Kahuna's Avatar
Kahuna
Just got a call from the Mech.Case is broken at the top,he says usually if it`s the c clip deal they break on the side of the case.Any thoughts?
Old Mar 19, 2012 | 02:16 PM
npccpartsman's Avatar
npccpartsman
Not sure about the location, but here's your answer. IIRC that snapring circles virtually the entire case.
Old Mar 19, 2012 | 03:07 PM
Mark Kovalsky
My thought? You need a new case.
Unrealo4
Aug 27, 2012 05:40 AM
woody367
2004 - 2008 F150
Mar 7, 2008 09:33 AM
diesel_dan
Jun 6, 2007 12:44 AM
V10Drooly
Modular V10 (6.8l)
May 6, 2004 07:33 AM
