automatic column for a C6
Old Apr 27, 2003 | 04:22 PM
zakt's Avatar
zakt
Currently have the 360 with the 4spd trans and will be putting a 460 with a C6 in my 67' F350. What steering column can I put in to work with the C6 with shifting on the column?
Thanx,
Todd
Old Apr 27, 2003 | 04:25 PM
Mil1ion's Avatar
Mil1ion
Well, The wiring from a 73-79 will be slightly different but nothing you can't alter.
Hazard light switches are located in a different spot.
Any auto column from 67-79
The 78-79's also had tilt steering available plus they came with a plastic shroud around the column to the dash.
Old Apr 27, 2003 | 05:40 PM
zakt's Avatar
zakt
now Im converting my 67' F350 to 4x4 so the stock gear box will not work will a 78-79 4x4 gear box work or?
Old Apr 27, 2003 | 09:06 PM
frog's Avatar
frog
Lightbulb automatic column for a C6
Go get you a B&M Megashifter for pickups. Easy bolt on and works a lot better than the factory column shift. Less work all around unless you are going for the factory look.
Good Luck.
hardward
Jan 17, 2017 05:14 PM
1974xlt
Aug 22, 2016 08:20 PM
T_Cooksey88
Mar 17, 2016 11:23 AM
rwrogers
Dec 1, 2013 09:06 PM
Jason Ellison
Nov 19, 2013 10:58 PM
