thermostat-stupid question
Old Mar 14, 2012 | 07:22 AM
85bobtail's Avatar
85bobtail
I bought a Stant thermostat yesterday for my new intake. I long ago got rid of the old intake and thermostat. I don't know what end of the thermostat goes towards the motor. In the past, the thermostats were marked with "to rad" on one side, this did not have the marking. A picture or diagram would be very helpful-Thanks
Old Mar 14, 2012 | 07:59 AM
Gary Lewis's Avatar
Gary Lewis
The coil spring goes into the engine/manifold.
What engine is it? If a 302 0r 351W, which I suspect since you mentioned the intake, you may need a self-adhesived gasket. Some of thermostat housings don't have a positive way to keep the 'stat in when you turn it to put it on, and the 'stat falls out w/o the gasket stuck to it. Don't put any sealer on the housing if you are using that kind of gasket as the adhesive won't stick to it.
Old Mar 14, 2012 | 08:27 AM
Rogue_Wulff's Avatar
Rogue_Wulff
LOL, the 300 uses the same type of housing and gasket, but bolts onto the front of the head. No idea why Ford designed their engines with the t-stat sitting vertical. The 351M/400 is the only one that I can think of that has a horizontal t-stat.......
Old Mar 14, 2012 | 08:30 AM
82f100460's Avatar
82f100460
If your question is "which end goes toward the engine?"...here is a simple picture.
The side with the sprng and the "bulb" in the middle is the part of the thermostat that senses the coolant temperature. So you want that facing the enginge since this is the coolant you are wanting to control the temperature of. Hope this helps
Old Mar 14, 2012 | 08:33 AM
Gary Lewis's Avatar
Gary Lewis
There is always one smarty-pants that has a surgically-clean engine, so clean that he wears surgical gloves to keep his hands off it, and goes around taking pictures of everything.
Old Mar 14, 2012 | 08:34 AM
82f100460's Avatar
82f100460
429/460 have a horizontal houing
Old Mar 14, 2012 | 08:36 AM
82f100460's Avatar
82f100460
hey now...those gloves and engine belong to Google!!!
Old Mar 14, 2012 | 08:40 AM
Rogue_Wulff
Wouldn't surprise me. I haven't worked on a 429/460 in years, and have never owned one, so I couldn't remember.
Might be others too, but not that were available in these trucks, with the possible exception of the 3.8L V6. Haven't messed with one of those, ever........
Old Mar 14, 2012 | 08:58 AM
Archion's Avatar
Archion
Veteran: Marine Corps
The "arrow point" always points towards the radiator in the hose, that's how I remember.
Old Mar 15, 2012 | 07:36 AM
85bobtail's Avatar
85bobtail
Guys
Thanks for the help! I thought the spring side went to the motor but wanted to check to be sure. Its been years (20+) since I messed with a thermostat and they use to stamp on the thermostat "to rad" on the arrow side. I guess it cost manufacturer too much to do this or include a diagram or picture on the carton or a piece of paper in the package. I did see they (Stant) did have a diagram on their web-page-ain't this computer age great...................................
hman108
Jan 14, 2018 05:54 PM
mike_94f250
Oct 20, 2011 09:34 PM
alanc77
17
Jan 30, 2011 10:11 AM
straightsixer
Dec 3, 2008 07:58 PM
