A question of 4 connections: what are they?
#46
#49
#51
#53
on
This is page 6-33 from the Chilton manual.
Surrounded in yellow (lower) is NOISE FILTER; is that the capacitor, and is it somewhere under the distributor?
I've highlighted the regulator in yellow (upper), and that same icon doesn't appear for a noise filter. Chilton oversight?
Lastly, the green arrow points to a BRN/PNK line running directly to the coil, and on to the starter relay. Is this BRN/PNK line tied somewhere else in the harness, instead of directly to the coil? Because I definitely don't see it.
Festus starts right up and runs like a top - I'm just obsessing...
The trucks with gauges (ammeter and Oil pressure) are wired different.
The Capacitor on the voltage regulator is not installed if the truck never came with a factory radio. However when these go bad, it can cause a direct ground short in that wire. Someone might have removed it to eliminate a problem. Still inconclusive.
Connector #2: Both the trailer and Fog light relay plug in here.
depending on the option you get.
On the fog lamp harness extention, there are two brown wire plugs, one male and the other female. One plugs into the main harness, and the other is left open to plug the trailer lights harness into it if so equipped, or it remains open like on your truck.
#54
on
I'll try to address the question posed by WJ here, but we answered it via PM. Anyway, I pulled that capacitor off of Dad's truck as Rusty didn't have one. The # on that one is E1AF-18832AA, and a quick Google found several of those.
WJ found the capacitor that is attached to the coil on ebay, but it is a different capacitor, at least from a connector standpoint, as shown in the attached pic with the regulator cap on top and the coil cap on the bottom. And, their #'s are written between them, although I'm not sure of the prefix on the coil cap as I can't tell for sure that it is a "1".
Brown is, indeed, used by the front marker lamps, tail lamps, parking lamps, license plate illumination, roof-mounted marker lamps (if equipped), headlight-on buzzer,, one or two other things inside the cab that I forget at the moment.
There should be a connector like that #2 behind the driver's side kick panel, down near the parking brake assembly; this supplies power for the roof lights.
These trucks were wired for every option available. This made it easier to install at the dealer if so chosen. If you find an empty plug, more than likely it's for a option your truck did not come with.
I am not sure what you're' referring to, but I can say that my truck originally didn't have a tach or gauges and I had IIRC a male connector with a black & green (or just green, ir just black, I don't remember) wire(s), the other end was at the coil (which was also connected to the module IIRC).
On trucks with idiot lights, the tach plug remains open as there is no plug for it in the main harness, or it plugs direct to the computer (if equipped).
On trucks with gauges the plug is connected to the main harness, and/or computer. Even if there is no tach in the dash.
300-6 engines only have the Green wire.
V8's have both Green and black because the tach has to be grounded "twice" on the "8" terminal of the tach to read correctly for a V8.
#55
Mucho good information, thanks to all who pitched in for the cause. I'm sure a lot of folks have benefited from the answers posted here.
I called Green Sales a couple of days ago and they didn't have the F6UZ-, which apparently can fetch a hefty price.
I never heard back from Partspring. No further comment.
So I called Green again today, and gave 'em the number that Gary found on the yellow (voltage regulator) capacitor: E1AF18832AA. The friendly folks at Green cross-referenced it for me, and sure enough, they had one. Five bucks.
Festus definitely had a factory radio at some point, and I'll see in a few days if this capacitor improves the reception on the '84 Ford radio I installed. It has that same ground-to-frame arrangement, and I've got a wee bit of static, so we'll see if this helps.
#56
#57
#58
The hood is part of the shielding for the radio antenna. Remember the '69 1/2 Road Runner 6-Packs - the ones with the lift-off fiberglass hoods? A buddy of mine had one and the radio reception was awful - all you could hear was ignition. Yup, common problem for them as that hood did no shielding. And, btw, it did have resistor plug wires.
Sorry, missed the question. But, I don't understand the question. What part are we talking about? The ground?
#60
on
The radio antenna has to be a certain height for proper radio reception, to pick up the frequency waves. FM radio is in the 3 meter bandwidth and is broadcasted vertically as well as horizontally.
Unfortunately to have a antenna that will catch the whole wave would have to be approximately 11.11 feet long (Different for each channel) for FM reception. There are tricks to make the antenna shorter and the Ground Plane is one of these.
The hood of the truck, the roof, etc... become part of the antenna.
This article will explain it better than I could.
Ground plane - Wikipedia, the free encyclopedia
Using a Fiberglass hood reduced the effective "length" and reception of his antenna by two-thirds, or 75%.
