f-150 chip?
Old Mar 12, 2012 | 08:04 PM
1975 390's Avatar
1975 390
f-150 chip?
hello all i have a ford 1994 f150 with a 5.8 4x4 and i was wondering if there is any chips or power commanders out there that anyone has tried that worked well for them.... im not looking for 100 hp just a little more pick up and diffrent shifting times lol
thanks for the help
Old Mar 12, 2012 | 08:46 PM
Midnite1987's Avatar
Midnite1987
simply put NO.......
do a 6liter tuneup to start... then from, there from what i have read headders and exhaust. then cam.
Old Mar 12, 2012 | 08:48 PM
1975 390's Avatar
1975 390
6 liter tune up??? explain
Old Mar 12, 2012 | 08:56 PM
Midnite1987
ignition upgrade and timing bump (no 56K) - FSB Forums
have a read
Old Mar 12, 2012 | 09:04 PM
rla2005's Avatar
rla2005
X2
Old Mar 12, 2012 | 09:05 PM
GNR22's Avatar
GNR22
A chip for trucks like these will simply bump the timing to make it more aggressive. And for the low introductory cost of FREE, you can do that yourself.
A 6litre tune up was created on the forum posted above by a guy with the screen name 6litre. It's just new plugs, wires, cap, rotor, timing advance, and coil. I think that's everything. It really perks the motor up with the simple bolt on replacements. But after that, get a set of long tube headers, a better exhaust system that flows much better, and enjoy. The other thing to know is that a cold air intake does no amount of good for these motors as the intake system is already very efficient. As for shifting times and all, what transmission is in your truck?
Old Mar 12, 2012 | 09:07 PM
Midnite1987
the 6liter also inclused addint new plugs and gapping them to 55-60 from the factory 45thou gap
Old Mar 12, 2012 | 09:37 PM
Nick_lebbad's Avatar
Nick_lebbad
chips are amazing in turbo diesels.. but gas motors..? really? my father has a dodge dakota that he put a chip in to give him a whopping 1-2mpg more per gallon.. catch is he has to run premium.. which doesn't actually make it worth it.. he swears its doing him a world of good but he is one of those guys who hears it from someone and tells it to everyone.. honestly if you are looking for some good gains.. these guys have said enough no need for me to say the exact same thing.. but chips won't do you a thing..
just my advice.. do whatever..
Old Mar 12, 2012 | 09:40 PM
Midnite1987
In our trucks its not worth it. As previously said All they do is bump the timing.
On newer vehicles it does make a difference
Old Mar 12, 2012 | 09:44 PM
Nick_lebbad
yeah they work great on the hondas with the adjustable cam settings and stuff like that..
Old Mar 13, 2012 | 10:49 AM
Kemicalburns's Avatar
Kemicalburns
what size tires are you running also? This is important to know because anything larger then a 31" tire will cause the e4od to not shift properly until the PSOM has been properly calibrated. not to mention the effect the tire size in combo with gearing in the truck will all play a factor in how it performs.
bobby738998
Computer Chips & Tuners
Apr 22, 2009 11:12 AM
waltg
Dec 11, 2008 04:53 PM
TC_xplorer
Nov 10, 2002 12:58 PM
garyda
Feb 17, 2002 12:49 AM
