So what did you do to your 6.0L today?
  #11311
Old 11-25-2015, 03:55 PM
884x4broncoII's Avatar
884x4broncoII
884x4broncoII is offline
pulled my gauge cluster pulled it apart cleaned the dust from the inside of it and polished the plastic lens.
  #11312
Old 11-25-2015, 04:00 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Fixed my rad hose leak and took her for a nice spin.
  #11313
Old 11-25-2015, 04:27 PM
Macrosill's Avatar
Macrosill
Macrosill is offline
Nice! How did you separate the lens from the housing without breaking it?
  #11314
Old 11-25-2015, 05:33 PM
884x4broncoII
un click the locking tabs and lift it off. just watch the trip reset button lifting it off and putting it back together and be careful of the needles while your cleaning
  #11315
Old 11-25-2015, 06:13 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Well I did it... Ordered a 2016 F150 Lariat today.
This example is a 2015 Kingranch, but shows the Blue Jean Two Tone and 20" wheels
Now the waiting begins.
Josh
  #11316
Old 11-25-2015, 06:34 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
This is pretty cool. I thought I was the only one that went through this kind of trouble. It makes the truck feel new again. I hate a dirty cluster. I have done mine 2 times in the last 3 years.
  #11317
Old 11-25-2015, 06:49 PM
Macrosill's Avatar
Macrosill
Well now I fel like an idiot. I had popped a couple of those tabs but then it seemed as though the guages were attached to the black plastic and the lens was stuck to the black plastic with some glue.
I was half way there and gave up! We need a facepalm smilie.
  #11318
Old 11-25-2015, 07:03 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
You bailin on us Josh.....LOL
  #11319
Old 11-25-2015, 07:14 PM
884x4broncoII
i recently bought this truck and it lived out on a gravel road so it was especially bad. normally every couple years under normal conditions keep them pretty nice. i first learned about taking them apart and cleaning them working as a mechanic at a used car dealership. really does feel a lot nicer driving something with a nice clean gauge cluster.
it is glued to the black plastic (the rings around the gauges) but its not glued to the gauge faces. don't remember exactly how many clips there are but quite a few all the way around once you have them all un-cliped it lifts right off with ease should not have to force anything. getting the cluster out was much more a pain than taking it apart.
it is a little bit of a pain getting all the crevasses cleaned out on the back side as the rings are glued to the plastic if yours is as dirty as mine was. if its not too bad a lot of times a quick blast with a air hose is all they need once you get them apart.
  #11320
Old 11-25-2015, 07:16 PM
klbrown's Avatar
klbrown
klbrown is offline
After sitting all week in just below freezing temps overnight. It fired right up,
clattered for a couple a seconds and settled down to a nice idle. Drove it about
15 miles to pick up my daughter's new washer/dryer. Small Sear's outlet store
and no one there to help load them. They had a small fork lift but no one knew
how to use it and wouldn't let me. I just walked them up a couple of 8' 2x4s, but
I'm getting older and that stuff isn't as easy as it once was.
Ok, rant over. Happy Thanksgiving to everybody.
  #11321
Old 11-25-2015, 07:35 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Josh
Sweet! Are you keepin the 6.0?
  #11322
Old 11-25-2015, 07:37 PM
Bullitt390's Avatar
Bullitt390
Haven't decided 100%. I could swing keeping it, but it will sit for extended periods of time and that bothers me to do that to a 6.0.
Either way, I'm here to stay in the 6.0 forum.
Josh
  #11323
Old 11-25-2015, 08:00 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Josh
When you get it I want to know how well it gets along with the VCM2 clone.
On other notes I changed my fuel filters the other day and almost did not
take a bath in diesel. I got one coat sleeve when some dribbled down the frame rail.
This has to be the first time I have ran the full 15K and I think I'll go back to 10K now.
What I really need to do is pull the tank and HFCM and clean all the lines and parts.
Ir almost looks like sand.
Sean
6.0L Tech Folder
  #11324
Old 11-25-2015, 08:03 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,517 Likes on 2,161 Posts
Congrats on the new ride Josh, I had to take a double look to make sure you said F150..... Nice truck.
  #11325
Old 11-25-2015, 08:04 PM
Bullitt390's Avatar
Bullitt390
Sean
6.0L Tech Folder
Will do. The newest I have tried it on was a 2014 F250 XL 6.7 and it played nice.
The only thing that has been hit n miss have been Mazdas for me.
Josh
Quick Reply: So what did you do to your 6.0L today?
