So what did you do to your 6.0L today?
  #8296
Old 04-02-2015, 09:00 PM
Rellick's Avatar
Rellick
Rellick is offline
Originally Posted by acf6
I would paypal you some $ for them/shipping/ if you had some. that would be awesome
Shipping is all I really care about. I have extras, actually. PM your addy, and we'll talk about details.
  #8297
Old 04-02-2015, 09:09 PM
acf6's Avatar
acf6
acf6 is offline
PM sent
  #8298
Old 04-02-2015, 09:24 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
yes it does! it was amazing how much room there was once you get all that crap out of the way.
-Open petcock to drain coolant (until it stopped)
-Took the air intake out
-Took out drivers battery and tray (disconnected pass battery connections)
-Removed the small coolant hose from degas bottle to radiator and also took my coolant filter out
-Took cold side intercooler pipe out
-Took upper radiator hose off rad and folded it back out of the way
-Disconnected fan clutch connector
-Pulled drive belt off the alternator
-Removed 2 8mm bolts on top of fan shroud
-My shroud had already been cut so i removed the 4 self tappers holding it together...im not sure i had to remove them each separately or if i could have just pulled it all out...
-Removed upper fan shroud
-Removed lower fan shroud (it just pulls straight up)
-Removed 4 15mm bolts that hold on fan surround
-Pulled fan surround towards nose of truck and put my gearwrench removal tools on the water pump pulley and fan clutch nut
-Removed fan clutch/fan/fan surround all together
-Swap fan onto new fan clutch, 6 1/2" (i believe) bolts
-Remove 4 10mm bolts on water pump pulley (needed some whacks with a hammer to come off)
-Remove 4 10mm bolts on water pump (also needed few whacks)
And reassemble...really wasnt anywhere near as bad as i thought. Happy i finally got it done
Something that made me wonder was there were a bunch of black specs in my coolant i drained out... i ended up filtering it out into another 5 gallon bucket before i poured it back in. Ive had a coolant filter for 50k miles and changed the filter 4-5 times already and theres still stuff in there. Coolants been flushed a lot
Why was the battery, air filter, CAC tube removed?
Josh
  #8299
Old 04-02-2015, 09:27 PM
Rellick's Avatar
Rellick
Rellick is offline
This is one of the latest things I've been up to.
And powder coated it.
Put new clearance lights on too, but I need more pics for them.
  #8300
Old 04-02-2015, 09:34 PM
acf6's Avatar
acf6
acf6 is offline
Josh
Just seemed like it'd make my life easier at the time. I needed to take out the air filter anyways because i pinched my gauge wires under it. I definitely think i could have left the battery in there but the other 2 gave me more room
  #8301
Old 04-02-2015, 09:51 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Awesome tks for that. Sure beats starring at it for hours scratching your head trying to figue out the best way
2006 F350 4X4 Mishi 200° tstat, IPR EGR delete/up-pipe
  #8302
Old 04-02-2015, 10:01 PM
One Cylinder's Avatar
One Cylinder
One Cylinder is offline
Changed the fuel filters on the '05. Normally I have a shop or the dealership do maintenance but I decided to do it myself. The primary filter went out and in as expected. The secondary filter cap; what a piece of garbage. The 1/2" socket ftting just fell appart, had to chistle it out. They must have hired the village idiot to design that cap.
  #8303
Old 04-03-2015, 03:38 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
OOOPs no clue why they put that stupid thing that way. Unless it was
to make money by selling you a new one. Your best friend is a socket
that fits the top. That way you no longer pop the 1/2 square again.
Sean
  #8304
Old 04-03-2015, 09:08 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
let the ole girl try to break my hand. The hoods on these are heavy
was checking the fluid this morning, a gust of wind hit and the hood fell down with my hand in the corner. The dern thing even latched. I could barely reach the latch and get it pushed enough to pull my hand out of the corner. Didn't break anything though.
  #8305
Old 04-03-2015, 09:51 AM
FordFamily6's Avatar
FordFamily6
FordFamily6 is offline
Have been battling a critter in the engine bay. Couple weeks ago only my defrost was blowing.... Hmmm. Looked under the hood and vacuum lines by vacuum pump were chewed up. Fixed it, then a couple days later, rodent struck again. Chewed up what I fixed and the wiring to the AC, 4wd solenoid and other stuff. Not knowing what the rodent was I set a mouse trap on each battery. Next day found both traps tripped and on the passenger side, the suspect dragged one over to the other side. At that point I figured it was a squirrel so I filled a bowl of pecans and set it on the ground under the truck next to the front tire. Couple hours later, bowl was tipped over and missing the pecans. Off to get a live catch trap....set it and a few hours later....GOTCHA! Spent 3 or 4 hours the next evening soldering, rewiring, and running vaccum lines.
  #8306
Old 04-03-2015, 10:52 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
I would have proceeded to execute the offending critter.
Sent from my Telegraph using IB AutoGroup
  #8307
Old 04-03-2015, 10:53 AM
mhoefer's Avatar
mhoefer
mhoefer is offline
Jess, that's a pain. I have had a few camping trips where squirrels were my primary source of worry.
  #8308
Old 04-03-2015, 11:00 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Originally Posted by MisterCMK
I would have proceeded to execute the offending critter. Sent from my Telegraph using IB AutoGroup
Agreed, he would have met either Mr.Smith and Wesson or if I was in a bad mood, Mr.Remington, a shotgun.
  #8309
Old 04-03-2015, 11:36 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
is that for the front or the rear axle?
  #8310
Old 04-03-2015, 11:44 AM
Rellick's Avatar
Rellick
Rellick is offline
Oh, whoops!
That's an OEM '08 aluminum rear cover for the Sterling 10.5/10.25 SRW.
Quick Reply: So what did you do to your 6.0L today?
