So what did you do to your 6.0L today?
came from but instead he made a left and risked the bridge and lost.
Still I can't get over the number of small trailers getting the A/C knocked off the tops. You would think they feel it.
Did you see the truck that stopped at the intersection. Then turned left away from the trestle. Then backed up and turned almost like he was going to go back to where he
My Forest River Wildcat is in the 12k range & the golf car & trailer is about 1200 #'s, truck loaded is about 10k. It tows great and I find myself backing off often, especially when you're creeping up on 80 mph.
Many states limit you to atleast have the lead trailer a 5er and all have a max length limit, usually 65 feet. I'm just under at 64' 8" the best I could measure.
One of the biggest things for these trips is the tool/fuel box I added in the bed. It is 91 gallon plus the stock 38 puts me in FL without getting off for fuel stops.
Also an update on the GPS, I had to reset it and it's fine now. Except I lost my saved files of fuel use and favorite places I had saved. No big deal.
So today we site see'd some and added some more miles on the truck for the trip. Ol blue is running flawless. Off to FL in the AM.
Spent a bit today with Ed over at FICMrepair. Got some new stainless pipes on the way. Turbo back with kat and resonator.
I think Xander heard me tell Ed I wanted to keep the Kat and Xander thought I said cat not Kat, He is up here making friendly
and trying to type. I went with the heavy band clamps so I would have to deal with any welding.
Now as I understand it you start at the turbo getting thing tight? Any hints will be helpful because been a long time sense I put my
last exhaust system on and this one is going to be a bit bigger.
You installing an aftermarket cat, or keeping the stock one? I did the turbo back MBRP from Ed and started at the cat and worked back, put all the hangers on first. Got everything installed snug enough to hold it, but loose enough to let stuff move around, once everything was lined up I went back and tightened everything down. i would start at the turbo and work back from there, just snug enough to hold everything inline, but not so tight that you can't adjust the joints.
Mark
Mark
Factory Kat.
New down pipe. I am getting rid of all the rusty crap. The hit that I had in Aug broke the top out of one of the
arches that goes over the rear axle so I have exhaust coming out from under the bed now. I am also getting
rid of the 4" down pipe and going to a 3.5" with 4" from the Kat back. That should give me back some low end.
Today I laid the MLV down. It's mostly done. I struggled to come up with a good method in my mind until I started doing it, that's when I said to my self to put a large piece down and reduce the number of joint. That turns out to be the best way. There is no need to cut things into smaller pieces.
Which means 4 feet across and going the whole length of the floor on the driver side. Then I just cut any relief that is needed. It turns out the heat gun helps dramatically. Only the front of the front seats needs some cut. Everything else the heat gun would work good. After that, I put a long narrow strip on the passenger side from front to back. Things look so good that I didn't need to glue down at all. I plan to glue a bit later, but very little. The heat gun does the job beautifully.
. They hold the pipes where you want them and won't deform the slip joint so if you have to disassemble or realign you will be able to with ease.
