2-speed differential questions
Old Mar 11, 2012 | 09:09 AM
Firecracker 50's Avatar
Firecracker 50
Is it worth changing to a 2 speed diff and what kind of increase road speed will it provide? Is there another method of shifting diff range than the vac diaphragm, maybe an aftermarket or more modern servo motor that would move the shift lever?
Old Mar 12, 2012 | 06:48 PM
38 coupe's Avatar
38 coupe
It really depends on what rear axle you have right now. The highest ratio I remember hearing of was 5.14 available in the single speed axle on the F-4s. The high ratio on the F-5 & F-6 two speeds were not that high. Find out what you have and plan from there.
The two speeds truck axles in the 30s were cable or rod shifted. You could always make up linkage and go that route.
Old Mar 12, 2012 | 07:34 PM
Stephen67's Avatar
Stephen67
Mine has 5.83 and 8.11, I also have 38" tall wheels. Those gears with smaller tires will give you a faster off the line speed, but you'll top out at like 35mph.
Old Mar 12, 2012 | 10:01 PM
Firecracker 50
I believe I also have the 5.83. Don't know what the 2-speed is yet
hillbillyk
Large Truck
Sep 6, 2021 08:48 PM
Boxhead
1947 and Older Ford Trucks
Nov 18, 2018 01:03 AM
Rozay
Jun 28, 2015 09:25 PM
kaj223
Large Truck
Apr 12, 2010 02:26 AM
Ty_Yota
Nov 28, 2009 04:40 PM
