2-speed differential questions
Old 03-11-2012, 09:09 AM
Firecracker 50's Avatar
Firecracker 50
Firecracker 50 is offline
Is it worth changing to a 2 speed diff and what kind of increase road speed will it provide? Is there another method of shifting diff range than the vac diaphragm, maybe an aftermarket or more modern servo motor that would move the shift lever?
Old 03-12-2012, 06:48 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
It really depends on what rear axle you have right now. The highest ratio I remember hearing of was 5.14 available in the single speed axle on the F-4s. The high ratio on the F-5 & F-6 two speeds were not that high. Find out what you have and plan from there.
The two speeds truck axles in the 30s were cable or rod shifted. You could always make up linkage and go that route.
Old 03-12-2012, 07:34 PM
Stephen67's Avatar
Stephen67
Stephen67 is offline
Mine has 5.83 and 8.11, I also have 38" tall wheels. Those gears with smaller tires will give you a faster off the line speed, but you'll top out at like 35mph.
Old 03-12-2012, 10:01 PM
Firecracker 50
I believe I also have the 5.83. Don't know what the 2-speed is yet
hillbillyk
Large Truck
09-06-2021 08:48 PM
Boxhead
1947 and Older Ford Trucks
11-18-2018 01:03 AM
Rozay
06-28-2015 09:25 PM
kaj223
Large Truck
04-12-2010 02:26 AM
Ty_Yota
1999 to 2016 Super Duty
21
11-28-2009 04:40 PM
Quick Reply: 2-speed differential questions
