Aerostar Ford Aerostar
Old 11-12-2014, 06:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Fuel System Guides
Print Wikipost
Fuel pump replacement through floor
Old 05-22-2012, 10:22 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
From what I can gather most pumps out there now are airtex. Even ford..
The box I got said carter on top. Federal mougal also. Everyone is in bed with airtex.
I will keep it as a spare for my other two vans but I still need a better pump for my nice van...I'm afraid motorcraft is airtex also.
Dick
Old 06-11-2012, 09:22 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Ok so I did alot of research and it looks like I'm going to buy a denso fuel pump..
Dick
Old 06-12-2012, 08:33 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Yeah, while Denso isn't OE for Fords, they are an OE manufacturer for Toyota, and they are definitely not a rebadged Airtex.
Old 06-12-2012, 06:38 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Just ordered the sock so I can't wait for the pump. The van starts hard hot...hard to prime pump...We are going to boston for the forth of july to see the tall ships and other stuff...then to ct to see family..
Dick
Old 06-12-2012, 07:56 PM
Jose A.'s Avatar
Jose A.
Jose A. is offline
don't forget a new fuel filter to go with the new pump and Happy July 4th!!
Old 06-24-2012, 07:06 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Ok quick Q?
Should I reinstall the fuel pressure damper or use the hose supplied with the pump?
Dick
Old 06-26-2012, 10:06 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
So I lost the damper as the new pumps don't need it I'm told. I do need the duck bill rubber thing on the return line if anyone has one off an old assembly..orange in color.
Dick
Old 06-28-2012, 11:13 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
nice pump can't hear a thing. Going to try the van when temps go up in a few days.
Dick
Old 07-11-2012, 10:42 AM
Jose A.'s Avatar
Jose A.
Jose A. is offline
nls Ford parts
FYI I have a friend a in Brazil who can get me nls Ford parts; He works in a Ford distributor. If you read some of the stickers in your Aerostar, many parts say "Made in Brazil". I just purchased the Brazilian version of the High Mounted Stop Lamp which is a lot better quality than the piece of junk made by "Truck-Lites" in the USA.
if someone has the Fuel Pump original part number as it relates to the Aerostar, I can find out if still available there and the price. But let me warn you that mailing costs from Brazil to USA are not cheap.
Being an old car collector, I have learned that sometimes you have to bite the bullet and pay the price to get original parts for old cars, (ask me how I know), I've had to order Jaguar parts from Australia and UK. The Aerostar is a collector van no matter what anyone says.
I've been following this thread and it amazes me that Ford would stop supplying a part as important as a Fuel Pump for the Aerostar. But the old saying "seek and ye shall find" holds true no matter the age of the car, parts are available, maybe not in the USA, but they are somewhere else.
Old 07-11-2012, 11:39 AM
KhanTyranitar
I'm not sure where your vans are from, no parts in mine say they are made in Brazil. Everything I can see is made in USA, Canada, Mexico, France, and Germany. Nothing from Brazil that I have seen. Most (but not all) the stuff Ford makes in Brazil is for sale to South American models. The Aerostar was never built outside the US, and realistically, few were sold outside North America. I would think most if not all the Brazilian made parts are replacements that have been installed after the van was built. A large part of the problem is the high cost of importing goods into the US from South American companies.
Old 07-11-2012, 02:00 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
So I got in the new pump and I also put in a new regulator. I took it out to check for a vacuum leak which it didn't seem to have but now after changing it I don't go to defrost anymore on hills. Go figure.. The van starts almost perfect on a heat soak condition so I'm pleased with the outcome. I only paid 60.00 for the pump so I have no complaints since they go for $120.00. If you get one of these pumps you have to get the filter to go with it.
I eliminated the damper and used the hose supplied with the pump. Just got back from a 1000 mile trip to boston and Ct..All went well van ran like new got over 20 mpg.
Dick
Old 07-11-2012, 04:26 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
It sounds like you may very well have had a vacuum leak in the old regulator, or the old fuel system was working so poorly that you were forced to hold the throttle open long enough that it drained all the vacuum reservoir. Either way, glad it's working for you.
It's been a long time since I had to fight the fuel pump in my van, so I forgot: what is this damper that you're referring to?
  #28
Old 07-11-2012, 04:37 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Its a bulb looking thing right above the fuel pump...Supposed to even out pulses and noise..This pump is way quiet. Almost can't hear it. I changed the pump cause it would start really hard after hot soak...!/2 way up mt washington I stopped to look around and when I went to start the van it wouldn't start. Took about a couple of minutes. The pump wouldn't prime it was really noisey..When it started it barely ran for 30 seconds then it was fine so I figured time for a pump..
Dick
  #29
Old 07-12-2012, 01:15 AM
KhanTyranitar
Same problems I was having, only with me it was doing it with new aftermarket pumps and leaving me stranded out of town. Glad the Denso pump worked for you.
Richard2212
05-25-2018 03:43 PM
KhanTyranitar
Aerostar
07-12-2014 09:51 PM
Turbo_Bimmer
09-21-2009 08:46 AM
Texas Mad Man
01-25-2009 05:20 PM
DantheMan
1978 - 1996 Big Bronco
09-10-2001 10:39 PM
Quick Reply: Fuel pump replacement through floor
