95 4x4 Break Problem
Old Apr 26, 2003 | 11:03 PM
TwoF150's Avatar
TwoF150
I replaced the calipers and wheel cylinders as well as pads, rotors and drums. I adjusted the star wheel and blead the breaks at all points including the master cylinder and still have weak spongy pedal.
Any recommendations?
Old Apr 27, 2003 | 12:12 AM
billman's Avatar
billman
ABS? If so, make sure you bleed that as well. After I did all my bleeding, I still had a soft pedal that would eventually reach the floor. Replaced the MC and all was well.
Good luck.
Old Apr 27, 2003 | 12:34 AM
steve83's Avatar
steve83
Why did you have to replace all the slave cylinders? Do you have a shop manual (Haynes, Ford CD, etc.) with a bleed procedure? There's a pattern you should follow.
Old Apr 27, 2003 | 07:46 AM
TwoF150's Avatar
TwoF150
Guys,
Brake overhaul was recommended by the Ford dealer on a newly purchased truck. After completing the workI feel that they were probably over zealous in their recommendations but the truck has 130K so I replaced it all and am trying to wrap it up.
I followed the manual and worked from the farthest point to the closest. I then bled the master cylinder and still have the soft pedal.
Could a trip to the dealer with a pressure bleeder work?
How do you bleed the ABS?
Never ending break job.
Larry
Old Apr 27, 2003 | 09:44 AM
billman's Avatar
billman
From the underside of your truck on a rail, just below the MC, you will see a unit with a brake lines going to it and from it. There is a bleeder valve on it (just smaller than you regular brake bleeders). Bleed it the same way you do your brakes.
Old Apr 29, 2003 | 07:00 PM
TwoF150's Avatar
TwoF150
Billman,
It was the MC. After replacement everything is back in working order.
