Help with removing broken off starter bolt
Old Apr 22, 2003 | 08:56 PM
boris's Avatar
boris
In the process of doing an engine swap in my 1987 F150 pickup I could not get one of the starter bolts out. The previous owner had the bolt head all rounded off and the only thing I could do was to grind the head off and now the stud is sticking out of the tranny about 1 1/2 inches. I have tried spraying it with wd 40, pb blaster, and cannot get it to move. Does anyone have any ideas on what I might be able to do to get it out???? I know I can grind it flush and drill it out, but drilling it straight and trying to get an ez out in there would be tough. Would heating it up, hurt the casting of the tranny??? Please help!!!!
Old Apr 22, 2003 | 09:09 PM
luke_trash's Avatar
luke_trash
if it were me, i'd get a big ol nut, like 3/4" or 1"
and weld it to the stud. then use a big ol wrench to get it out.
(after soaking it in diesel fuel)
Actually I'm too impatient. I'd grab the stud with some big visegrips and clamp them down as tight as I could and turn.
Old Apr 22, 2003 | 09:24 PM
kioolt's Avatar
kioolt
Try using a stud remover. It's a tool that has a hole in it they you put over the stud (broken bolt in this case). You use a 1/2 inch square drive to turn the tool. It grabs the stud and unscrews it. It's great for what you described.
Old Apr 22, 2003 | 10:05 PM
444stroker's Avatar
444stroker
snap on sells the stud removers, they're sort of like an inverted ezout. they work pretty good, but if one of them won't do it, weld a nut on what's left and give it hell
Old Apr 23, 2003 | 08:49 PM
vman's Avatar
vman
Could carefully heat the transmission case.I have the exact same problem on my 93. I broke it off putting a starter in. There is enough there to locate the starter on. I left it alone and even though I've had to change starters, I haven't had a problem with it in three years.
Old Apr 29, 2003 | 08:19 PM
rlaggren's Avatar
rlaggren
Heat often helps with this type of problem. A cheap propane torch is a fairly gentle heat that shouldn't harm anything - I think it maxes out at 1100 F., and of course the work piece need not be heated tha much. If you get the female part up around 300F (ie., well above boiling temperature) while avoiding heating the male part (as best you can), it will probably come right out with vise-grips. Have them preset to the right grip and ready at hand - or put them on ahead of time. If you have cleaned the parts well first, you won't even get much smoke.
Rufus
BrownBrutus
17
Jan 31, 2013 10:18 AM
Beav93
20
Jan 14, 2012 07:12 PM
MUJA1001
Jan 22, 2011 09:16 PM
BlueOvalRage
22
Aug 6, 2009 09:12 PM
Hiflyer746
Sep 21, 2004 07:01 PM
