Fuel tank problem
Old Mar 10, 2012 | 10:33 AM
mustanginca's Avatar
mustanginca
Fuel tank problem
I have a 93 F250 7.5l dual tanks. Finally decided to fix my back tank and want to buy what I need before I do the job. My truck can idle off the back tank but when I push the gas it starts to die. I've tried fresh gas and new filter no luck. After sitting awhile my front tank fuel gauge no longer works. I'm assuming the float is stuck. My question is will to new sending units solve my problems? Also trying to shop for them there are so many variations of gas tanks in our trucks anyone have a part number for them? Thanks.
Old Mar 10, 2012 | 11:04 AM
ctubutis's Avatar
ctubutis
Does your truck have in-tank pumps (low-pressure) and a single, high-pressure pump closer to the engine?
If so, my guess would be the back tank's pump has died; do you hear any fuel pumps running for a few seconds when you turn the key to RUN but not starting the engine?
Old Mar 10, 2012 | 11:07 AM
mustanginca
No I don't hear a pump run. I've never really traced the line into the engine bay to see where it goes.
I'm just trying to make it a day job rather than disassemble one day buy parts the next and reassemble. I plan on taking off the bed to access them.
Old Mar 10, 2012 | 11:16 AM
ctubutis's Avatar
ctubutis
Well, nobody here can tell you if replacing parts is gonna fix anything without first diagnosing it.
Some people here have wiring diagrams for your fuel system, maybe they'll stop by and post or maybe you can find them by searching through the archives.
If you have an ohm meter, you can put the leads on the motor's wires; if you don't get any continuity, the motor is burned out.
There are also various relays and impact sensors involved, but problems there generally manifest themselves as no-start conditions and it doesn't sound like you have those symptoms.
I personally wouldn't remove the bed for something simple like this, that's gonna be a half day by itself....
Old Mar 10, 2012 | 11:23 AM
mustanginca
Yeah I think I'm just gonna have to tackle it. The bed bolts are new that's why I was thinking of going that route. I'll try testing the pumps. Didn't realize it was such a complex fuel system.
Old Mar 10, 2012 | 12:04 PM
ctubutis's Avatar
ctubutis
Find the wiring diagram; not only are there wires for the pump, but also for the sending unit.
Old Mar 10, 2012 | 01:43 PM
subford's Avatar
subford
Sounds like the front tank FDM is bad along with its sending unit.
FDM:
Krisverde
18
Jul 17, 2015 07:47 AM
AWorley
Nov 18, 2012 08:34 AM
FuriouS
Jul 8, 2010 09:29 PM
FLgargoyle
Sep 5, 2009 03:31 PM
Ford_F-250_1990
Jun 4, 2007 08:38 AM
