Computer Chips & Tuners
stage one or two chip?
Old Apr 26, 2003 | 10:02 PM
aball73's Avatar
aball73
Question stage one or two chip?
I have decided to buy a diablo chip. Are the stage one and two chip identical as far as the performance program? I have a 92 with a stock 460/auto OD and don't plan on doing any mods other than a cat back. I plan on doing some pulling of a travel trailer. Is there any reason I would want to switch back to a stock program? I am leaning towards the one stage. 91 octane is only 10 cents more/gal.
Old Apr 29, 2003 | 10:09 AM
FTE Ken's Avatar
FTE Ken
Yes, the performance is the same. The only differences are the ability to switch to stock and the ability to add a third stage.
Old Apr 29, 2003 | 08:44 PM
tdmontg's Avatar
tdmontg
Ken, can you tell me why someone would want to be able to switch to a stock program?
I'm just curious. I would like to get a Diablo chip and read in another message where you said most people do not need the stage three for gas applications.
I would like to have the 87 octane option for 2002 F150 SC 4x4. What would you suggest?
Old May 8, 2003 | 07:29 PM
propellerhead's Avatar
propellerhead
Ok, I'm this |_| close to ordering a Diablo chip.
I have the same question though. If the performance program is much better, why would anyone want to flip a switch to go back to the standard program?
Also, my main concern is the speed limiter. I haven't seen anything that says it will change it. All I've seen are 'maybe's. Is this a hit-and-miss thing?
Old May 9, 2003 | 08:47 AM
FTE Ken's Avatar
FTE Ken
Switch to stock gives you the ability to run 87 octane if the need arises.
I would not suggest paying money for an 87 octane program. The only big benefit you'll get is the transmission tuning. The higher octane programs give a horse power gain.
Old May 9, 2003 | 08:49 AM
FTE Ken's Avatar
FTE Ken
There is no way to guarantee raising the speed limiter unless we've programmed that particular code before. Keep in mind that Ford has over 3500 different programs.
If you can give me your ECU code I'll tell you what I have in my files.
Royson12
83
Oct 11, 2014 08:53 AM
maticuno
1983 - 2012 Ranger & B-Series
15
May 27, 2004 08:24 PM
Brian429
Apr 13, 2004 05:14 AM
Colorado4x4
Nov 16, 2003 06:03 PM
nothingbutford
May 12, 2003 09:52 PM
