1978 - 1996 Big Bronco
78/79 RestoMod
Old 09-29-2014, 08:33 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Originally Posted by Skip1970
how is the piece mounted to the axle tube? can i see a pic is it a d60? i got some cage arms with weld on brackets i still need to fully install on my d60, your arms look really good tho.
The upper link is mounted with a bracket that is welded on to the lower.
Yes, the front and rear are 2003 F-350 axles.
  #452
Old 09-30-2014, 01:07 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
no, hows it attached to AXLE TUBE?
  #453
Old 09-30-2014, 09:23 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Oh, my bad Skip!LOL
These right here did the trick
Flat Bottom Radius Arm / Coil Mounts
Used some Ballistic Bushings in there, works beautifully!
  #454
Old 09-30-2014, 10:33 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Originally Posted by Raleigh1
Oh, my bad Skip!LOL
did you just use a arc welder or what? im going to weld mine with arc. hope it holds!
  #455
Old 10-01-2014, 06:00 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Did mine with my Lincoln MIG set up.
You will need to preheat the axle before welding to it or it may not get hot enough to penetrate.
I used an oxy-acetylene rig, the welds are still pretty ugly but they have good penetration.
  #456
Old 10-01-2014, 07:09 PM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
Good penetration is a must in welding and "other" things.
  #457
Old 10-03-2014, 05:21 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
I got the drag link built, I still have to paint it but the angles are spot on.
Also picked a cam and timing set. I went boring with a flat tappet Comp Cam CL32-208 and a double roller timing set. Ordered them on Tuesday and they arrived yesterday!
  #458
Old 10-04-2014, 10:04 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Finally settled on a gauge set, New Vintage Performance Series.
Just have to decide how I want to modify the dash to fit them.
  #459
Old 10-04-2014, 10:41 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
Those are nice. I might use a piece of sheetmetal and put those in my 79 Bronco.
  #460
Old 10-04-2014, 10:48 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
I think I am going to use some heavy gauge sheet metal to mount them in.
I should be able to shape close enough to mount in place of the factory cluster.
  #461
Old 10-05-2014, 11:06 AM
ManfredVonRichtofen
  #462
Old 10-05-2014, 09:37 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Pretty similar to what I have in mind but I will have on the 2 gauges and I will be painting mine black.
  #463
Old 10-06-2014, 06:35 AM
Toyman's Avatar
Toyman
Toyman is offline
I was thinking of doing aluminum when I build my dash.
Those gauges are cool!
  #464
Old 10-07-2014, 03:43 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
how reliable are them gauges? one part goes out you gotta replace the whole shebang!? i got some autometers and have a falure already. its on a sending unit i think tho.
  #465
Old 10-07-2014, 08:32 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Love those gauges!
Quick Reply: 78/79 RestoMod
