Injector o-rings ?
Mar 9, 2012 | 09:50 PM
Injector o-rings ?
Where's the best place to get injector o-rings, from Ford, or are some of the aftermarket ones better?
Mar 9, 2012 | 09:54 PM
I usually get mine from Riffraff or Dieselorings.com
Alliant is the kind your wanting.
Mar 9, 2012 | 10:00 PM
Clay, ford, or IH clay is around 7 buck a injector and ford and IH are around 14bucks
Mar 9, 2012 | 10:01 PM
Quote:
Originally Posted by
JamesHajek
Those are the ones I was looking at, from Riffraff. Thanks man
Mar 10, 2012 | 07:47 AM
Don't buy aftermarket. Believe me I found out the hard way.
Mar 10, 2012 | 10:45 AM
International was cheaper than Ford for me ....
Mar 10, 2012 | 06:56 PM
Riff raff was the cheapest I found.
Mar 10, 2012 | 10:29 PM
You know Bad, that picture of your O ring failure would have put me over the edge as I'm sure it did you. I tried to rep you for warning others but I guess I'm in jail.
Mar 10, 2012 | 10:39 PM
So are the Alliant o-rings from Riffraff ok then???
Mar 10, 2012 | 10:41 PM
Yep that's what you want. Alliant makes our injectors
Mar 10, 2012 | 10:45 PM
ReBilld
Yes sir, That's exactly what I would be putting on my injectors... Call and talk to Clay, great guy to deal with.
Mar 10, 2012 | 10:47 PM
Thanks for the info guys. I'm assuming I've got some bad glow plugs cause it's hard to start. If I plug the block heater up it fires right up. I got new Motorcraft glow plugs and I figured I'd go ahead and do the o-rings while I'm in there.
Mar 11, 2012 | 05:28 AM
Good choice. Also check the rocker bolts as well while your there.
Mar 11, 2012 | 07:31 AM
Mar 12, 2012 | 05:55 PM
heathrunkles
Thanks man !
