2005 Explorer tail light replacement
Old Mar 9, 2012 | 07:27 PM
TDC05's Avatar
TDC05
I havea burned out turn signal bulb. I am not sure how to change it. Do I remove he panels inside or can it be reached from below, outside? . it is still cold out so laying on he ground for an hour is not my first choice. I want to get it done quick.
thanx in advance
Old Mar 9, 2012 | 09:40 PM
shorod's Avatar
shorod
I think you'll find that if you open the rear liftgate there will be a couple of screws for each rear tail light lens assembly. If you remove the screws, then tug on the assembly, it will unsnap from the body. I don't recall though if you need to pull the assembly towards the center or towards the rear. I think you need to pull it towards the center.
-Rod
Old Mar 10, 2012 | 09:39 AM
TDC05's Avatar
TDC05
Thanks. Once it was daylight and not snowing, it made sense. The vehicle is dark blue and the screww headswere not too visible at night. All fixed.
Old Mar 11, 2012 | 10:24 AM
shorod's Avatar
shorod
Glad to hear you got it squared away!
-Rod
merc546
May 29, 2009 05:45 AM
pugster
Jan 31, 2008 12:45 AM
BroncoEx
Nov 7, 2007 08:46 PM
ejg
Aug 26, 2007 02:37 AM
groundhogg
Feb 19, 2007 06:55 PM
