STC FITTING REPLACED
Old Mar 9, 2012 | 11:42 AM
jerkypants's Avatar
jerkypants
Picking up my truck today for a grand total of 890.00
Replaced stc fitting, replaced the blue flex hose that comes out of turbo on passenger side, and a coolant hose, and checked the rail orings.
He suggests changing out coolant.
Can't wait to drive it, he says I really shouldn't need xtra guages with the engine stock. THOUGHTS?? If so...which ones?
Old Mar 9, 2012 | 11:50 AM
jerkypants's Avatar
jerkypants
Talking
Ps.
Thanks again to everyone on here, you are all a great help.
Extra thanks to Mchan, Bismic, Bpounds, Blade35, Piolet, etc, etc.
I hope I am not forgetting anyone.
Old Mar 9, 2012 | 12:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Stock or not, get the ScanGauge II ! You GOTTA monitor the EOT and ECT !
Old Mar 9, 2012 | 01:01 PM
jerkypants's Avatar
jerkypants
Yes, that I did want to get.
I understand there is some set up to it.
Is that something you leave plugged in while driving as well as scanning issues? Does it plug into the computer (obd) plug or does it need to be wired in?
Thanks Jerky
Old Mar 9, 2012 | 01:07 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
OBDII plug..... leave it in, take it out.... no problem. Yes, you do have to program in the spwecial codes you want. All available here or on the ScanGauge website.
Old Mar 9, 2012 | 01:24 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
ECT/EOT split, FICM voltage, engine voltage, and fuel pressure are musts. Fuel pressure can suck and the FICM will eventually die, might as well catch them before they take the injectors out with them. Watch the voltage so the alt/batts don't take out the FICM. Watch your temps so the EGR cooler doesn't crack and spill coolant into the intake. All that happens stock.
Old Mar 9, 2012 | 07:16 PM
BLADE35's Avatar
BLADE35
Maybe you have the Flash that Illuminates the CEL when the EOT vs ECT delta is out IDK
But Im with everyone eles get a scangaugeII going lots better to watch some things then wait for something to totaly Fail and Take Multiple things with it
Shure would suck to pop an egr cooler and dump coolant into the cylinders and lift the heads
Without any gauges NO Problem you just need a Bigger Bank Account
In time the SGII will pay for itself
I caught my alternator going out If I didnt have the SGII it could have taken FICM out and even Injectors the price could have doubled or tripled really fast
Is this an independant shop that told you dont worrey about gauges
Old Mar 9, 2012 | 08:53 PM
Piolet's Avatar
Piolet
You can hit the heart button in the top right of any post and throw some rep points (reputation) at the author
Old Jul 2, 2012 | 04:48 AM
Fal-308-Win's Avatar
Fal-308-Win
I just got done installing the revised STC fitting on my 6.0l for $63.00. It's a lot cheaper to DIY!
Old Jul 2, 2012 | 01:21 PM
m-chan68's Avatar
m-chan68
I will be the first person to agree. However, how much of your time did this take you? And how much is your time worth?
hasteranger
Aug 23, 2017 06:44 AM
Splash67
Mar 23, 2014 10:13 PM
Ian123
Mar 11, 2013 06:58 PM
A/Ox4
Sep 5, 2012 08:34 PM
robbiecox6
1983 - 2012 Ranger & B-Series
Jan 11, 2006 07:06 PM
