need some advice?
Old Mar 8, 2012 | 07:34 PM
dothedew192's Avatar
dothedew192
need some advice?
For quite a while now I've suspected my hpop was a bit under the weather. Just a few seconds of wide open throttle with my superchips tuner would throw the check engine light. the o rings on the hpop have started to leak, the easy ones to change, I'm not sure about the "non serviceable plug" yet, so today, to confirm my suspicions, I hooked up my solus scantool to the truck and did some wide open throttle runs and sure enough its maximum output on the runs was right around 1800 psi. I did at one time, when letting off see it hit 2600 psi. But that was for a split second, did another run and never saw it again. i'd like to pull the pump and get it remade into a t-500 but I really can't be without the truck for a long amount of time. I also don't have the 200 dollars to throw down for a core charge right now. So I'm in a bit of a pickle, I guess I should just tough it out and wait for the extra 200 dollars but it bugs the heck out of me to know my hpop is weak.
Old Mar 8, 2012 | 08:03 PM
BigAlsPSD's Avatar
BigAlsPSD
What was the IPR duty cycle at that psi? Was the code a 1211? Where are you located? It seems as though you are maybe getting a feeler for someone with a pump you could send as a core? If so I have a couple extras, maybe I could help...
Old Mar 8, 2012 | 09:44 PM
dothedew192
I'm not exactly sure what the ipr duty cycle was, I can run another test tomorrow and pay attention to that. the code 1211 is constantly popping up though. I'm located in northern new york, what is a feeler if you don't mind me asking? I certainly do appreciate your help sir. for sure.
Old Mar 8, 2012 | 10:35 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
LOL. "Putting a feeler out" is southern talk for asking someone for something without actually saying it. He is suggesting you are searching for someone with a HPOP you could borrow as a core. I grew up in Arkansas, so I am certified to translate
Mike
Old Mar 8, 2012 | 10:48 PM
BigAlsPSD's Avatar
BigAlsPSD
Yes, although I didn't know it was a southern thing... I grew up in Chicago, lol
OP if that is what you are after PM me your address, and I can probably get one to you next week, or when ever you need it.
Old Mar 9, 2012 | 07:39 AM
dothedew192
Lol. No kidding, you learn something every day. I certainly didn't mean to impose though. But yes, that would be absolutely fantastic. Then I can kill two birds with one stone. Get rid of my oil leaks and get rid of my half dead hpop. I'll send you a pm sir.
hav24wheel
33
Apr 10, 2017 02:10 PM
Absolute
Jan 8, 2016 05:58 PM
Robert6401
Feb 10, 2013 10:21 PM
Crewcab Turbo
Feb 21, 2012 10:28 PM
Pocket
Mar 7, 2006 02:26 PM
