3 codes need help
Old Mar 8, 2012 | 05:33 PM
KawiRider78's Avatar
KawiRider78
3 codes need help
hey yall
i have a 2004 f150 5.4 with 78,000 miles and i have a engine light on so i had my bud do a scan and 3 codes came up P0058,P0138,andP2270 i was hopeing yall could explain the problem and point me in the direction to fixing this problem thanks
Old Mar 8, 2012 | 06:24 PM
Coskid's Avatar
Coskid
Sorry bud I don't know those codes anyone got some information for him.
Old Mar 8, 2012 | 07:24 PM
KawiRider78
solved my own problem toke the 2 after cat o2 sensors out cleaned em engine light is off and the truck is runnin cooler
Old Mar 8, 2012 | 07:28 PM
Greg B's Avatar
Greg B
P0058 is HO2S control circuit high bank 2 sensor 2. P0138 is o2 sensor circuit voltage high bank 1 sensor 2. P2270 O2 sensor signal stuck lean bank 1 sensor 2. Hope this helps. You can find the diagnostic routine in the Ford Emmissions and Powertrain Control shop manual or equivalant manual from Chilton or Motor. Following the diagnostic routine in the manual helps you find the problem without just throwing parts on and hoping you got lucky. Usually all you need is a digital multimeter and the manual and follow the step by step process. Once you adapt to using this method you'll be pleasantly surprised how easy these things are to fix.
ericnj75
Aug 31, 2007 03:03 PM
alawens
1997 - 2003 F150
Apr 20, 2004 11:58 PM
fishes
Dec 6, 2003 08:43 PM
Jmorrell588
1983 - 2012 Ranger & B-Series
Jan 26, 2003 04:52 PM
96f150
Nov 19, 2000 05:30 AM
