4R100 Vs. ZF6
Old Mar 8, 2012 | 02:44 PM
grizzly11's Avatar
grizzly11
4R100 Vs. ZF6
which one will hold up better at 500 hp i was going to go to bts and have one done but have came across a whole truck for cheap that has a zf6 in it?
thanks
Jared
Old Mar 8, 2012 | 03:38 PM
duck fan's Avatar
duck fan
Because racetruck
With the ZF6 you would need to upgrade the clutch to handle that much power. Its more a question of what your goals are. A manual truck is hampered by the long sifts in the ZF6 so if you are looking to go fast, the 4R100 is your trans
Old Mar 8, 2012 | 03:53 PM
grizzly11's Avatar
grizzly11
with the 6sp its harder to get the turbo to spool correct? i want to lay down 500hp on the dyno and be able to compete wit the cummins n dmaxs but still be able to pull once in awhile
Old Mar 8, 2012 | 03:58 PM
timmyboy76's Avatar
timmyboy76
For me, it is. Doesnt come on til 1600-ish rpms.
Old Mar 8, 2012 | 06:30 PM
grizzly11's Avatar
grizzly11
ok how do you think a 71mm turbo is going to do with the 6 speed? the swap would be easy enough having the truck right? Im going to research the swap a little bit. It would probably be a wise chose to just get a dual disk for it right away if i do?
Old Mar 8, 2012 | 06:38 PM
BigAlsPSD's Avatar
BigAlsPSD
Kind of off topic, but...Last time I was at BTS his latest project was removing the 6 speed manual from a 2008 GT500 Supercharged Mustang and putting a 4R100 in it's place. Faster shifts with a good built auto, and a good builder can handle the power. I know not long ago he also did a trans for a shop with a 6.4 they removed the 5R110 and put a 4R100 in it's place too.
You will find a few ZF6 swap writeups CAMODOWN is the user I think of but he may not have actually done a writeup. Not terribly difficult though. I think all said and done though he had as much in it as a BTS with a lifetime warranty would have been, no smoking clutches either.
Old Mar 8, 2012 | 06:54 PM
grizzly11's Avatar
grizzly11
i have to money right now to tie up in buying this truck cheap and swaping trans and then selling it and then getting turbo n injectors but its up in the air bc i test drove a 6sp before and didnt like i thought the gears were to close together and ran the risk of putting it in low instead of second. With the auto i would at least have the peace of mind that its brand new just in an old case where with the swap i don't know any maintenance records on the truck n neither does the guy that has it. But in the long run i believe the bts would hold a lot longer than the handshaker with a dual disk from south bend to the every day driving and occasional hot rodding n racing, I guess some feed back from the guys that have a bts would be nice.
Old Mar 8, 2012 | 07:49 PM
bulla's Avatar
bulla
I really like driving a manual! But when it comes to my truck and it's twin with a six speed, I love my bts! Hammer down and go, don't look back, doesn't miss a shift, doesn't grind the gears, can load it up for one hell of a launch, and do one mean burn out! I'm sure this can be accomplished in a palm shaker but I just don't know if it can take that abuse like the bts is known for! Save yourself some trouble and skip the swap and spend that extra on your current truck. My .02
Old Mar 8, 2012 | 08:31 PM
grizzly11's Avatar
grizzly11
After further research I think bts is the way to go so bts it is I just get crazy ideas
Jaxon24
65
Mar 23, 2022 09:20 AM
KRAZY KRAMER
Nov 10, 2018 10:52 AM
cjp97-7.3
Jun 3, 2016 06:26 PM
Miller
Sep 24, 2007 08:00 PM
crack
15
Jul 6, 2006 11:58 PM
