gear ratio
Old Mar 8, 2012 | 01:47 PM
Heiro444's Avatar
Heiro444
gear ratio
what should my gear ratio be for my 295/70/18 on my 2007 f150 4x4? i have an edge evolution programmer and the mm size of tires is 2733. if im correct.
Old Mar 8, 2012 | 02:08 PM
Coskid's Avatar
Coskid
Are you regearing the truck and want to know what you would be best off going too or do you want to know what stock gears are?
Stock gears for your truck are most likely 3.73's.
If you plan to upgrade the best option would be 4.10's.
Old Mar 8, 2012 | 07:54 PM
Greg B's Avatar
Greg B
You tires are approimately 34.25" tall or in diameter. That's quite a lot taller than stock. You'd be better off by increasing you gear ratio by the same percentage as the diameter of your tires have increased for best performance. From a 3.73ratio, 4.10's would be close.
Old Mar 9, 2012 | 06:04 AM
shotgunz's Avatar
shotgunz
2733 is the unloaded tire diameter.
Accounting for 3-5% squish (flattening of the tire due to load) the diameter you want to put in the Edge is between 2597-2652.
Start in the middle and then confirm with GPS (instantaneous speed). An even better way to confirm is using the GPS's odometer vs. the truck's odometer over a 10 mile (or greater trip).
And yeah - you need to re-gear (or start saving money for a new transmission).
Old Mar 10, 2012 | 04:39 PM
V10man's Avatar
V10man
Guessing your stock tire was around 30" tall. Your new ones are 14% bigger. If you had 3.73 gears then adding 14% would be 4.25. So 4.10 gears would be close. 4.56 gears would be a bit over but would shine towing. MPG would suffer a little.
Old Mar 10, 2012 | 06:26 PM
Papa Tiger's Avatar
Papa Tiger
You're ok with 3.73 if you seldom tow and have 4.6 or 5.4. Doing 4.56 would be awesome for off roading and such. You're getting as good a gas mileage as you can get with what you have in it right now.
Old Mar 11, 2012 | 08:35 PM
hillbilly12384's Avatar
hillbilly12384
what ratio would be 10% more than a 3.55
Old Mar 12, 2012 | 05:06 AM
shotgunz's Avatar
shotgunz
1.10 x 3.55 = 3.905. But since 3.905 gears aren't available, you'll need 4.10 which is ([4.10/3.55 - 1] x 100) 15.5% larger.
Old Mar 15, 2012 | 12:20 AM
Heiro444's Avatar
Heiro444
Thanks a lot for the input. And yes I have 3.73 now with the 5.4
MurderMode
Feb 2, 2018 12:45 PM
Anomic
Feb 26, 2011 12:11 PM
TXPSD
6.7L Power Stroke Diesel
Feb 20, 2011 10:12 PM
Bonanza35
Feb 9, 2011 09:18 PM
afbrian13
Oct 4, 2007 09:22 AM
