cooling system
Old Mar 8, 2012 | 12:43 PM
gerry p's Avatar
gerry p
cooling system
hey guys,04 6.0 the hose that comes off the intake and goes to the degas bottle,should that have a steady flow or just a trickle?
Old Mar 8, 2012 | 01:50 PM
Unrealo4's Avatar
Unrealo4
It's just a overflow hose. It shouldn't have steady flow unless you have a coolant filter piped into it.
Old Mar 8, 2012 | 01:53 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I think the OP means this hose: the EGR cooler deaeration line, or whatever the technical term is. AFAIK it should be flowing coolant back the degass bottle, doesn't coolant come out of the EGR cooler and get split between the front cover with some going through the deaeration line?
Old Mar 8, 2012 | 02:08 PM
gerry p's Avatar
gerry p
Thanks guys, just wanted to double check.I've got high psi on coolant and just don't want to admit to myself that it's time for headgaskets.
eagleinms
Jun 10, 2015 12:24 PM
nathan66669
May 30, 2015 03:03 PM
mblanken881
Dec 20, 2011 08:04 PM
bhd
6.4L Power Stroke Diesel
Dec 13, 2010 12:48 PM
skoveng
Dec 14, 2008 08:57 PM
