Manual Hubs?
Old Mar 7, 2012 | 07:23 PM
diablodude64's Avatar
diablodude64
Manual Hubs?
This is probably a dumb questions, but is my 87 f250 6.9 going to have manual hubs or auto?
I would think manual, but I haven't pulled the front wheels off. The reason I ask is because the wheels on it have center caps that don't allow access to the hub if it's behind that.
So, if they are manual, is there a center cap for that?
Thanks, Kyle
Old Mar 7, 2012 | 07:38 PM
05victorylly's Avatar
05victorylly
I would guess they are manual. My 89 has manual hubs, not sure if they offered auto hubs then. but if they are covered by your center caps that's not going to work too well, unless you want to keep them locked all the time. Not good for gas mileage.
Midnite1987's Avatar
Midnite1987
If you have solid center caps, chances are your truck is a 2wd.... But if 4wd it should be manual hubs on that age of truck.
Old Mar 7, 2012 | 07:53 PM
diablodude64
It's definitely four wheel drive, but the wheels were put on it temporarily by the previous owner and then it sat and they ended up staying on it. I am thinking I'll use a hole saw to cut out the center of the caps if it doesn't look to tacky otherwise i'll leave them off.
Thanks, Kyle
Old Mar 7, 2012 | 07:54 PM
Midnite1987
Have a picture of the wheels?
That would be one heck of a center cap to be able to cover the 4wd hub
Old Mar 7, 2012 | 10:47 PM
Boss08v10's Avatar
Boss08v10
yes pic please.
Old Mar 7, 2012 | 11:07 PM
05victorylly
Yeah I i would imagine it would be enormous to cover everything.
Old Mar 7, 2012 | 11:27 PM
Big_Al59's Avatar
Big_Al59
Usually front covers means 2wd. Never seen a 4wd like that, pics?
Old Mar 7, 2012 | 11:58 PM
Midnite1987
Any factory front cover would have required hole for hub to stick through
Old Mar 8, 2012 | 12:02 AM
diablodude64
I'll get a picture, but I didn't mention that they are aftermarket wheels. I'll get a picture tomorrow!
Thanks, Kyle
Old Mar 8, 2012 | 12:03 AM
Midnite1987
It would e a royal pain in the a** to have to remove the wheel or even remove the hubcap to lock/unlock front hubs
Old Mar 8, 2012 | 07:57 AM
bashby's Avatar
bashby
Did they offer auto hubs on a F250 with dana 50?
With the transfer case in 2wd, rotate the front driveshaft a few turns in the same direction, if they are auto hubs and work they should lock.
Old Mar 8, 2012 | 11:27 AM
thechief66's Avatar
thechief66
Yes, but IDK about '87
Old Mar 8, 2012 | 12:22 PM
diablodude64
Okay, so I pulled the wheels and they are manual hubs. So I pulled the center cover out of the wheel and I'll drill out the center to allow access to the hubs.
I tested it, and its a night and day difference too.
Thanks, Kyle
Old Mar 8, 2012 | 01:01 PM
05victorylly
so they were locked or unlocked? what was the night and day difference? Traction or less resistance due to not spinning all those front diff parts?
