Injection Pump Tool
Old Mar 7, 2012 | 12:06 PM
Blitzcraig's Avatar
Blitzcraig
Injection Pump Tool
Does anyone have pictures of the tool used to remove the right side bottom nut on the injection pump? I would like to buy one or better yet just make one if I knew what it looked like. Its tough to get a wrench on that one.
Old Mar 7, 2012 | 01:01 PM
Kentwa's Avatar
Kentwa
I saw a picture where a guy just ground the heck out of the handle for clearance it wasn't anything special just gave him more room I did mine with a standard end wrench without to much trouble just time consuming.
Old Mar 7, 2012 | 01:25 PM
artfd's Avatar
artfd
Get a set of these: 5 Piece SAE Obstruction Wrench Set
Whichever box end fits the nut, grind it down, to make it thinner, so that the box end will clear the obstructions around that pesky IP nut. You might have to bend the wrench a bit.
You can buy a single obstruction wrench for this nut, it will likely cost much more than the entire HarborFreight SAE set does, though.
Old Mar 7, 2012 | 01:32 PM
Blitzcraig's Avatar
Blitzcraig
Good idea, thanks!
Old Mar 7, 2012 | 04:56 PM
mudguts's Avatar
mudguts
I just took and old 9/16" end wrench and ground it down on my bench grinder till it fit (around 3/16" of an inch thick) works great.
Old Mar 7, 2012 | 08:58 PM
jaluhn's Avatar
jaluhn
I took a 9/16" wrench and the torch and bent it about 1 1/2" from the open end. Also ground the end of the box end to get it to fit. The official wrench is a nice curved thing, but it's easy to make one. Just use the torch and a hammer....
ford2go
Garage & Workshop
Jun 1, 2015 07:37 AM
joe f350
Sep 9, 2010 04:59 PM
bshep
Mar 18, 2009 03:40 PM
kupiec20
17
Jan 30, 2009 10:03 AM
Mr.Ford 351W
Garage & Workshop
Oct 23, 2005 06:53 AM
