Spark Plug Gap
Old Mar 7, 2012 | 07:29 AM
Kaizer88's Avatar
Kaizer88
Spark Plug Gap
Got another one for yall. I changed my spark plugs not to long ago and gapped them at .044 and yesterday i changed them to .054 and now it seems like i dont have the power i did at .044. I have a 1989 302 is there anything bad that could happen with running the plugs at .044. This weekend I also plan on bumping the timing up to 14 BTDC as well
Old Mar 7, 2012 | 08:21 AM
rla2005's Avatar
rla2005
It takes more "punch" from the coil to jump the extra gap. If your coil is weak due to age or other factors then increasing the plug gap may not work to the desired result. What you are trying to accomplish is referred to as the "sixlitre tuneup". Increased gap, bumped up timing and the last part is good quality plug wires/cap/rotor and a hotter coil.
If you want to run with the increased plug gap you may as well pony up for a new coil, wires, cap&rotor.
Old Mar 7, 2012 | 09:17 AM
UncleCracker302's Avatar
UncleCracker302
^+1 what he said!
just did the new cap & rotor, wires, plugs, and coil (all MSD except Motorcraft plugs gapped to .055) and bumped timing 13.5* and my butt dyno felt the positive results! spend the extra money and make it truly worth the time and effort
Old Mar 7, 2012 | 10:13 AM
Kaizer88's Avatar
Kaizer88
how can i tell if my coil is weak? will this increase MPG by doing a 6 litre tuneup? man rla you are on top of your game you have answers to all questions...
Old Mar 7, 2012 | 01:53 PM
rla2005's Avatar
rla2005
You may have already answered that question. You opened up the plug gap and now you state you felt like the performance decreased. This could also be caused by cheap or faulty plug wires as well. By opening up the gap it is taking more "oomph" to jump the gap.
You could pull a plug, ground the electrode, crank the engine over then observe the spark. It should be a nice "fat" bluish-white color. If not start suspecting a less than stellar coil, but also keep in mind the plug wires can also be at fault.
It's matter of process of elimination unless you have a high voltage probe and oscilloscope to measure the voltage.
Many on this forum, and Fullsize Bronco where sixlitre haunts, have benefited from the timing/plug gap bump in power and some MPGs.
Old Mar 7, 2012 | 02:11 PM
Kaizer88's Avatar
Kaizer88
i know it aint the plug wires. i have msd plug wires
PRIMERED79 SHORT BED
Dec 30, 2016 08:14 PM
25
Jan 29, 2016 08:51 PM
qman
Jul 23, 2015 09:10 PM
kameronth
1978 - 1996 Big Bronco
Sep 19, 2005 11:06 AM
I6power
Mar 16, 2005 11:32 PM
