1960 f100 292/fordo with trans cooler with lines into block of motor? What to do?
Old 02-04-2012, 02:16 PM
56 ford custom's Avatar
56 ford custom
56 ford custom is offline
Ok I have a 1960 f100 with a 292 y block and ford o matic trans. I pulled the old motor out because it was on its last leg. Well the old trans has a cooler on the side of it and hard lines that go into the block of the motor where the water jackets are. The new trans I am pretty sure its air cooled. Which one to go with?
Old 02-04-2012, 06:20 PM
critterf1's Avatar
critterf1
critterf1 is offline
I'd go with the air cooled.
Old 02-04-2012, 06:29 PM
Drewmeister's Avatar
Drewmeister
Drewmeister is offline
Hello - this is funny because I had the same thing on my '67 when I pulled the tranny years and years ago. It had cooler lines routing coolant back to a box thing on the side of the tranny. I'd never seen anything like that.
I chose to plug the holes in the block and run the tranny fluid up to a B&M cooler in front of the radiator. I ran hard lines I pulled from a truck at the boneyard. It worked just fine.
Hope that helps.
Old 02-05-2012, 02:43 AM
56 ford custom
trans
Hope that helps.
Can you please post some pics?
Old 02-06-2012, 11:54 AM
56 ford custom
Can somebody post a pic of that conversion?
Old 02-06-2012, 01:08 PM
lance65's Avatar
lance65
lance65 is offline
pm sent.....................
Old 02-06-2012, 01:10 PM
lance65's Avatar
lance65
lance65 is offline
an aftermarket cooler will have two lines,one in one out.Most come with a mounting kit to mount it to your radiator.Hook up the tranny lines to it with oil cooler hose and mount it.done.
Old 02-06-2012, 02:09 PM
56 ford custom
The thing is that these libes arent tranny fluid its water. Does anyone here have a diagram for this or even a part number,brand or place I can get it? Anyone here done this before and have pics?
Old 02-06-2012, 05:38 PM
Drewmeister
Sorry, I made the change 15 years ago. I don't have any pix.
Old 02-06-2012, 05:41 PM
Drewmeister
Okay, now I'm caught up with the thread. Apologies for the double post.
What I'm talking about is changing the system from one that brings coolant back to the transmission to one that is more conventional and brings tranny fluid up to an external cooler or, more commonly, the radiator like you would see on a truck from the '70s for instance.
Is this what you want to do or would you rather keep the factory system that routes coolant back to the tranny?
Old 02-06-2012, 05:52 PM
56 ford custom
I mean I would like to keep most of it original but I want it to cool well too. Is the original cooling that bad?
Old 02-06-2012, 06:42 PM
tbirdscott's Avatar
tbirdscott
tbirdscott is offline
Vehicles have used water to oil tranny coolers for decades with no trouble. Why do you want to get rid of it so bad?
Scott
Old 02-07-2012, 12:49 AM
56 ford custom
Scott
I wasnt trying to get rid of it, just trying to figure out which would be the best for what I want and need the truck for.
Old 02-07-2012, 01:32 AM
tbirdscott's Avatar
tbirdscott
For just normal use I would say stick with the OE cooler. Add a temp sensor to monitor it if you are concerned or plan on towing/hauling regularly.
Scott
Old 02-07-2012, 09:38 AM
56 ford custom
Scott
How would I go about installing a temp sensor? I wount be towing or hauling at all. If I were to install a trans cooler on it how would I go about doing that without changing my radiator? I am mmost likey sticking with stock just checking my options.
Quick Reply: 1960 f100 292/fordo with trans cooler with lines into block of motor? What to do?
