1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Priming Fuel Filter 6.7
Old 02-08-2017, 10:57 AM
stufarmer's Avatar
stufarmer
stufarmer is offline
16' F350 6.7 Diesel
Is there a need to re-prime the Fuel System after taking a Fuel Sample from the Frame mounted Fuel Filter. (yellow ****) ?
How much Fuel do you drain for your average Sample ?
I've never done this.
My dealer does this (I've watched them) on my truck when I take it in for service.
I've always had excellent service from Gator Ford in Tampa.
They are a Ford dealer, but only sell Ford Trucks at this Dealership.
Old 02-08-2017, 11:53 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
No for fuel sample as long as you only drain 8oz of diesel.
You only need to drain a few ounces as the water will be in the bottom of the fuel filter.
rickbrad's Avatar
rickbrad
rickbrad is offline
I'm pretty sure the yellow **** is used to drain water from that filter housing. The owners manual says to drain it every oil change or when the light comes on. From what I have read about fuel contamination on the 6.7L, I'm going to keep a really close watch on it.
Old 02-08-2017, 12:40 PM
Deuce40s's Avatar
Deuce40s
Deuce40s is offline
The manual recommends a monthly check. I wouldn't go much longer than a month either.
pmoney1983
08-19-2012 08:22 AM
Larry NCKS
6.4L Power Stroke Diesel
05-21-2011 09:01 PM
F3504ME
08-23-2007 07:30 PM
Powermoon
03-29-2007 03:04 PM
Tym
01-15-2006 12:09 PM
Quick Reply: Priming Fuel Filter 6.7
