Maybe I'm mistaken, but this looks like the cap that's been out for awhile that doesn't fit our trucks (unless you have a 450/550 C&C!). The 250/350 isn't listed in the supported vehicle list...
You may be correct. I just happened to run across it for the first time in a search this morning.
I think the price sounds a bit high, but if you plant them they will grow overnight into a giant beanstalk that will reach up thought the sky. Then.....No...wait.
I think that was a different item.
Educate me: are people really stealing DEF? I mean, its like what, $22 for a couple of gallons that lasts a couple of thousand miles? Really?
no, it's to prevent accidental cross contamination of DEF to fuel or reverse which will result in a very expensive repair bill. With the zip tie or locking door, you're more likely to know immediately if someone was tampering.
Well, it looks like the GM trucks have the most "secure" location for DEF fill, then (under hood). GM diesel vans and RAM trucks have the filler next to the fuel fill, but in both cases the caps are basically jammed in nearly on top of one another. The fill location under the hood is in an awkward spot on the GM trucks too. In my opinion, the Ford design is BY FAR the best, with good access to both caps and decent spacing between them, thanks to the nice wide (steel) fuel door on the Super Duty. I can't ever imagine "accidentally" pouring DEF or diesel in the wrong opening - the caps are different colors, shapes, and drastically different sizes.
What would be nice is for Ford to electrically lock / unlock the fuel door along with the passenger doors.
WOW, at that price I ordered two, in fact thinking of ordering some more, not sure how Ford is letting them go that cheap, my guess is they are taking a loss on them at that price
