Driver seat.
Old Mar 5, 2012 | 10:05 PM
mczarski's Avatar
mczarski
Driver seat.
Hey guys, just wondering if you have repaired the seats before. My driver side has lost all spring, and is flat on the left side.
Old Mar 6, 2012 | 12:42 AM
TexasGuy001's Avatar
TexasGuy001
The springs may have sagged some, but most likely the foam is also smashed down. You can try to use a piece of indoor/outdoor carpet or jute etc to build up the foam and compensate for either of these issues, but inserting it between the foam and springs.
Old Mar 6, 2012 | 01:19 AM
882tank's Avatar
882tank
I agree it is most likely the foam. Not that big of a deal if your good with hog ring pliers. Depending on how much you want to spend you can pick up a kit to rebuild the foam from LMC.
Old Mar 6, 2012 | 07:47 AM
GNR22's Avatar
GNR22
The other, probably easier, option is just replace the seat.
Old Mar 6, 2012 | 05:19 PM
mczarski's Avatar
mczarski
Seat
Hey thanks guys, I just checked LMC, and they have the foam kit for $35, not bad at all. Does anyone know if it's a specific foam, or could I find something similar locally? I am in kind of a hurry, I'll be traveling cross country in a couple weeks, and want some cushion on my rear end.
Old Mar 7, 2012 | 01:06 AM
lmd91343's Avatar
lmd91343
Like TexasGuy001 said, try checking the BOTTOM of the foam where it meets the springs. Many times the springs (thin parallel wire on two inch spacing, if I remeber correctly) will cut into the foam. A piece of carpet or someting similar between the foam and springs will fix the sag and it won't cost a cent. It's quicker and cheaper!
It won't fix the torn fabric.
Old Mar 9, 2012 | 08:21 PM
mczarski's Avatar
mczarski
Ok, I see what your saying, I will give the carpet a try first, thank you.
RAY1986F150
Apr 23, 2013 07:42 AM
clarkbd
1966 - 1977 Early Broncos
Feb 28, 2013 10:43 AM
53OlderThanMe
Jan 18, 2009 06:32 PM
jseim44
Mar 27, 2008 03:57 PM
mwilson
Jun 2, 2003 01:30 PM
