no fuel pump noise.....
Old Mar 5, 2012 | 05:39 PM
streetlude95's Avatar
streetlude95
my truck wouldnt start the other day because all of the sudden the fuel pump wouldnt pump any fuel. no hum coming from back there, so i bought a pump, and right when i started to drop the tank the pump started to work again! so i said screw it, put everything back togather and returned the fuel pump. now the problem is back 3 days later... i think it might be a bad ground wire because of the intermitten connection.. but i have know idea what i am looking at.. what should i do?
Old Mar 5, 2012 | 05:50 PM
KevGun8994's Avatar
KevGun8994
Replace the pump. sometimes messing with it or jaring it will cause it to kick in. My front pump went out a few months after I installed new tanks "with over half a tank of gas of course!!". So I reached up between the frame and bed and smacked it a few times and it kicked in. Immediately drove it till empty switched to rear tank to get home and took it out and replaced the pump.
Old Mar 5, 2012 | 05:51 PM
rla2005's Avatar
rla2005
What year/model/fuel type truck are you referring to?
Old Mar 5, 2012 | 05:53 PM
streetlude95
its a 90 f150 5.0 with the 2 tank setup. and i too have a **** load of gas in my tank(rear) and the front tank has been dead for over a year. fml
Old Mar 5, 2012 | 06:05 PM
rla2005's Avatar
rla2005
Make sure you are getting consistent power to the pump(s) before you start dropping any tanks. You could have a bad relay, fuse link, dash tank selector switch or wiring problem.
Use this diagram for reference:
courtesy of oldfuelinjection.com
That was for a 1991, it should be the same or very similar to your 1990.
Old Mar 5, 2012 | 06:10 PM
streetlude95
thanks man
Old Mar 5, 2012 | 06:35 PM
rla2005's Avatar
rla2005
Let us know how it works out for you.
Old Mar 6, 2012 | 05:23 AM
streetlude95
Well I finished dropping the tank last night and on my lunch break im gonna test the pump on a battery and hopefully it will not run so I can have this problem resolved.
jwilly53
May 6, 2012 05:30 PM
tony b
Nov 4, 2006 10:10 AM
nastruk95
Sep 25, 2004 01:22 AM
moose94
Jul 19, 2004 12:18 PM
DantheMan
1978 - 1996 Big Bronco
Sep 10, 2001 10:39 PM
