I have a 2011 F250 that I am trying to change the yellow marker/turn signal lens on the powerscope sideview mirrors to clear with LED. Has anybody changed theirs that can help me with the removal of this lens. I have tried to remove but am affraid to snapping the mirror housing.
Thanks, Mike
Ifyou angle the top mirror in towards the door you will see a tab behind the mirror on the bottom outside corner. If you push the tab with a screw driver them you can pull the directional lens off
I am a fan of clear, I have installed LED lights on the front spoiler, fire&ice lights under doors, changed the roof clearance lights. Everything is clear lens with Amber LED and now in the process of changing the 3rd brake light, taillights and mirror lights.
