Dealer A/C Question
Old Mar 5, 2012 | 10:28 AM
Dorsai's Avatar
Dorsai
Dealer A/C Question
Having successfully fixed the heat on my '80 F-150 (300 engine), my next project is to fix the (dealer-installed) air conditioning - hopefully in time for the warm season. My question concerns the differences between my old and new compressors.
The old compressor has blocks bolted to the top of the housing for the hoses, which are attached via hose clamps:
My new compressor, however, has threaded ports integrated with the housing:
I am operating under the assumption that the only thing this means is that I will need to source pre-made hoses with the appropriate fittings. Is this correct? The only other difference between my old and new compressors is that the new one has only a single-belt pulley - I'm assuming I can transfer the pulley from the old compressor to the new.
Old Mar 5, 2012 | 11:01 AM
Dorsai's Avatar
Dorsai
So after I posted the above it occurred to me that maybe I should use my brain, and go look up my new compressor on the NAPA website. Sure enough, it's listed there as a replacement for FACTORY air, not dealer air.
Is there any way to use this with my dealer air setup, or do I need to get it exchanged for a dealer-style compressor? The reason I ask is that the return process will be a little more complicated than usual, given that I got it from my brother, who got it from his buddy who gets a discount at the parts house...and they're all 60 miles from here anyway.
Old Mar 5, 2012 | 11:15 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Best bet, is to get the correct item. You could convert everything over to use that comp, but with the extra cost and effort, it wouldn't be worth the trouble. Especially if the replacement was bad.......
Old Mar 5, 2012 | 11:19 AM
ctubutis's Avatar
ctubutis
Why the change?
You might exchange the inlet/outlet fittings between the two pumps. Will likely involve some seals but that might be easier.
I would remove the fittings from the old pump, it looks like there are two bolts holding each one on, see what kind of seals are there. It's hard to see your new pump exactly in those pictures but I would imagine the parts would be interchangeable.
Old Mar 5, 2012 | 11:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D2AZ-19703-C .. "York" dealer installed A/C Compressor (Motorcraft YC-11) / Obsolete
Last MSRP: $299.25 / Dealer net cost: $143.64.
Applications: 1972/83 E/F100/350 & Bronco / 1972/79 FoMoCo Passenger Cars.
18 available NOS ..but I'd suggest looking for a rebuilt.
Green Sales Co. in Cincinnati OH has 10 of the 18 available. These could be NOS or they could be FoMoCo rebuilts.
If interested, call and ask: 800-543-4959.
Old Mar 5, 2012 | 01:10 PM
Dorsai's Avatar
Dorsai
That was my first thought as well, but it won't work. The outlets on the new compressor are molded into the top of the housing, so it wouldn't be possible to remove them to replace them with the fittings from the old compressor. I could *possibly* swap the tops of the compressor housings, *if* the internal plumbing lines up correctly. But that's really more work and risk than I want to get involved with.
NumberDummy, thanks for looking those parts up for me. As it turns out NAPA sells a new compressor for this application, and I just got the word from my brother that I can do a one-for-one swap with the incorrect compressor that I have. So I'll have my new new compressor next week - but I appreciate the pointer to another source nonetheless.
Old Mar 19, 2012 | 08:54 PM
Dorsai's Avatar
Dorsai
I was able to swap the compressor I had for the correct one, with no hassles due to the oddball acquisition process. So far, so good.
Now...where do I get new hoses for the thing? I'd like to replace all of the 30+ year old A/C hoses with new ones, but where do I get them from? I've checked several major parts chains (NAPA, AutoZone, Advance) as well as LMC and NPD, and nobody seems to have hoses for dealer air. Factory air, yes, but not dealer.
Some of these hoses are just hose that I can probably get anywhere, but some have unique fittings. Am I going to have to get these custom made? Surely *someone* out there sells them.
Old Mar 19, 2012 | 10:51 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I'd go and get them made if they are bad. Some select o'riley stores for instance can make them for you from scratch.
Old Mar 20, 2012 | 10:06 AM
Dorsai's Avatar
Dorsai
That's what I'm afraid I might have to do. Do you know if they can typically procure new fittings, or do they need to reuse my old ones? Can old hose fittings even be reused safely?
Old Mar 20, 2012 | 10:57 AM
f100jim's Avatar
f100jim
There are no "fittings" with dealer installed air. It is just pieces of hose cut to length. They slip onto the hose barbs and get a hose clamp around them, just line in your picture. I had new hoses made for my dealer air '82 years ago. A local parts store made them for me. They just pulled the roll of hose off the shelf and cut me the pieces that I needed.
Old Mar 20, 2012 | 11:39 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Dorsai, if you have a good independent AC shop in your area, they may be able to come up with the fittings or service valves you need. Most of the dealer installed stuff I used to see had service valves on the compressor. Most of my older Ford factory stuff just had hoses to pipes that went right on the compressor head. The last Ford I had with a York or Tecumseh compressor was my 77 F150.
Old Mar 20, 2012 | 11:42 AM
Dorsai's Avatar
Dorsai
Not strictly true, at least not in my truck. The hoses in the engine compartment are as you describe...but the hose that attaches to the expansion valve under the dash has a fitting. That may be the only one...I haven't pulled all the hoses yet to be certain. I suspect the other hose that comes into the cabin has a fitting as well.
Old Mar 20, 2012 | 11:58 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Factory A/C would not terminate the lines inside the cab, they are at the firewall with the heater connections.
Old Mar 20, 2012 | 01:07 PM
Dorsai's Avatar
Dorsai
If only I had a time machine to go back to 1980 and warn my grandfather to buy the factory air option...
Old Apr 18, 2012 | 08:57 AM
Dorsai's Avatar
Dorsai
OK, so instead of cluttering up other peoples' threads with my random questions, I'll clutter up my own...
I'm pretty much ready to go on the A/C. I've got my new (correct) compressor, new hoses, a new drier. I'm going to keep my existing evaporator, condenser, and expansion valve, since (a) I have no reason to believe they're bad, and (b) some of them are a bitch to remove.
So, questions:
  1. How much oil do I need for the system? My compressor is new, but because I got it as a swap for my old one with some amount of unknown shenanigans going on, I don't have a manual for it. It's a Climate Control Inc. model EF-210R, obtained through NAPA. I can't find anything online that unambiguously gives the oil quantity.
  2. I took the tape off one of the ends of my drier a couple of months ago to check the port size. Being a big dummy, I didn't realize that the tape was there to keep the unit sealed, not just to protect the port. So now the dryer, with its load of dessicant, has been sitting partially open in my garage for months. Is it likely to be saturated, and therefore dead? Do I need a new one?
As always, thanks for any help.
