Height Adjustable Pedal Mod?
Old Mar 5, 2012 | 08:52 AM
2SONS's Avatar
2SONS
I have a 2000 Limited Ex without height adjustable pedals, which is fine for me but a problem for my 5'1" wife. Is there any way to add height adjustable pedals? If so what would be involved with this mod?
Old Mar 5, 2012 | 09:31 AM
UrbanXX's Avatar
UrbanXX
I'm sure this can be added but money wise you would need to buy used parts. I think you would need the adjustable cylinder, wireing and switch. The master cylinder should be the same. I am not for sure if the brake pedal bracket is the same or not. The best way to do a change over like this is first find one in the wrecking yard. These are my thoughts.
The person to contact is SUNLINE FAN on the Excursion fourm he more than likely may even have the parts. He's the go to guy for Excursion parts as of now.
Old Mar 6, 2012 | 06:02 PM
2000 7.3psdEx's Avatar
2000 7.3psdEx
So all the bolts line up from the '00's pedals and the '02 and newer power adjust pedals??
Old Mar 6, 2012 | 06:11 PM
UrbanXX's Avatar
UrbanXX
I have never looked at a 00 but most of the parts interchange. The best way to find out is look at one and compare.
You may have to change the cylinder bracket under the dash, I have the adjustable one on mine. I will see if I can find one that dosen't and compare it if you can't find one. I may be going to the wrecking yard this week.
Old Mar 6, 2012 | 06:22 PM
2000 7.3psdEx
ok cool because ive been wanting to do this mod for a while. I already have all the necessary parts required for the adjustable pedals. (sorry)
Old Mar 6, 2012 | 06:31 PM
2SONS's Avatar
2SONS
Urban - Thanks for the response, this will help in the future, when I have the funds to attempt this.
2000 - It wasn't really a high-jack, it helped clarify further questions I had.
Old Mar 6, 2012 | 06:36 PM
2000 7.3psdEx
Ok..and also you will need to change the lower dash with one that contains the switch unless if you want to wire up a toggle switch instead. I'm going to try this over the weekend and ill post pics of the progress to help.
Old Mar 6, 2012 | 06:43 PM
UrbanXX's Avatar
UrbanXX
Can you not mout the switch in your lower dash by cutting it out ?
Old Mar 6, 2012 | 06:47 PM
2000 7.3psdEx
You could possibly put it right under the little cubby but on the 02 and up, the switch is right next to the cubby.
Old Mar 6, 2012 | 06:54 PM
UrbanXX's Avatar
UrbanXX
Mine is right next to the chubby hole.
I don't know how its wired up but that would not be hard to do even if you had to use an inline fuse.
Old Mar 6, 2012 | 07:41 PM
2000 7.3psdEx
Yeah but im not sure if a relay would be needed though.
Old Oct 15, 2013 | 11:01 AM
fordboy2's Avatar
fordboy2
anyone do this yet?
Old Oct 15, 2013 | 02:21 PM
Misky6.0's Avatar
Misky6.0
post #10, states parts order from dealer, so IF you can find the pedal assembly in the junk yard - you should be good to go - you can wire up a simple switch if you want vs. get the actual Ford switch.
https://www.ford-trucks.com/forums/9...le-pedals.html
Old Oct 15, 2013 | 03:32 PM
fordboy2's Avatar
fordboy2
ok I figured they could be put in, I can get all the parts out of a wrecked excursion I need for 40 bucks the guy said. Just wanted to make sure it was doable before spending the 40 bucks.
Old Oct 15, 2013 | 03:52 PM
Apocalypse's Avatar
Apocalypse
Damn, I would kill to get the parts for this! Anyone have a yard around them that wants to sell me some parts?!?
