Oil & Lubrication
Which weight to use
Old Apr 26, 2003 | 08:55 AM
KentuckyCountryBoy's Avatar
KentuckyCountryBoy
Which weight to use
Guys I apologize if this has already been discussed, but, I will be hauling a pop-up camper around this summer and was wondering if you all had a suggestion for what oil weight I should use. Thanks for your input.
Old Apr 26, 2003 | 09:52 AM
rusty70f100's Avatar
rusty70f100
Which weight to use
Sounds like fun. Wish I had the time to go camping. Anyway, I would suggest that you run a good 10w30, and look for one that is dual rated SL / CI-4. Have fun!
Old Apr 26, 2003 | 10:17 AM
John with beastly 302's Avatar
Which weight to use
I would sugjest Mobil1 10W-30 with a napa 1515 Gold oil filter. I go camping to with my 1991 F-250 with my Lance camper and other varios toys Boats etc.
Old Apr 26, 2003 | 12:25 PM
mikemc's Avatar
mikemc
Which weight to use
A good 10w30 would be fine. I like Castrol GTX, but Chevron Supreme and Motorcraft are very good and are available cheap at walmart.
Old Apr 27, 2003 | 12:14 AM
c_rossman's Avatar
c_rossman
Which weight to use
I just put castrol 20w-50 in my 1993 F250 with a 460, seems to have quieted things down alot, The motor has a little over 202,000 miles though. I also use 20w-50 in my 1990 F250 with the 300-6, Also quiets things down @245,000 miles.
Old Apr 30, 2003 | 03:20 PM
mikemc's Avatar
mikemc
Which weight to use
Rossman, I'm thinking you could benefit from one of the excellent heavy duty diesel rated oils, like 15w40 Chevron Delo 400. But if the 20w50 Castrol works, not a bad choice.
