Just added turbo,low boost,high egt's? need advise
#31
OK ! I have an update and I need some more input from ya'll... I went back and checked everything and found some leaks I had overlooked ..dont know how but i did.. a big one was under the snail the gasket got pushed out.. and i had read in another post about making a road draft tube.. i made one simple a hose out of the cdr and down.. i left the house and wow.. she hit 7 psi and had a ton of power and egt's only went to 750 !!! came off the exit ramp and she was blowing oil EXTREME out the front and rear main.. had to put 6 qts back in her.. I know i know rdt was stupid very stupid... well i got her back home and she blew another 6 qts out in about 4 miles to give you an idea of how bad... well got off work today came home and hooked cdr back to breather and topped off with oil.. started her up and hardly no leaks.. warmed totally up drove to my job 10 miles away used steam cleaner cleaned everything ... left heading home got 2 miles down road and she blew all oil out again !! Im totally confused??? I even changed and put another cdr on it between there and the house blew all oil out again.. so what could be causing this ??? Is it possible the cdr is closing ?? the rdt i had made the first time consisted of a tube out of the CDR straight to the ground. note*** I just read something about punching holes in the bottom of the valley pan ?? by not doing it , it can appear that a rear main is leaking... when i drove it that 10 miles after reconnecting the cdr tube back to breather thats all that was a mild occasional drip back on crossover pipe.... but when its puking oil its really puking oil. out from front main and out the back.. seams like all of a sudden high crankcase pressure.. im gonna go broke from buying oil !! someone please give me some ideas ! was reading more on a rdt... should I try eliminating the cdr and run a hose straight out of the valve cover?? im in a loss
yes, punch holes in that baffle under the valley pan...needs it to drain all the extra oil or it will leak like crazy and the valley drains down the back of the block so it would appear its coming from another location. if your cdr is fully functional (going threw the intake) it shouldn't be blowing out the seals like a RDT that isnt venting enough or properly would
#32
7psi at 750 egts is nice and safe, leaks make a big difference
#33
yes where the oil return goes, while your back there check out the rear of the valley pan gasket and make sure its not leaking anywhere along there. so you think you are blowing boost into your crankcase? maybe past rings?
i wish i had a leak that would keep leaking....i have an oil leak, t-case leak, front axle leak and it all happens for like 2 days then disappear for the next month, very frustrating when your trying to get everything all sealed up.
try punching the holes and setting up the cdr then let us know if your still blowing oil
#35
dipstick does not blow out and it don't move free either. I got the turbo from gonecrazy and he said it was good on his trk... I would think that putting holes in valley pan to let oil drain would solve prob.. Engine never had blow by before it only has 131k on it. Would I have to remove intake, pump,ect to change v pan gasket?
#36
on
Yes, you need to pull the intake to replace the VP, but not to poke the drain holes.
This is not a Failed Turbo issue ... It appears to be a crankcase pressure issue.
The reason I asked about the dipstick is if you have excessive crankcase pressure it might blow it out, but if it's stuck in pretty good it may not.
Jury rig a low pressure gauge to your dip stick tube so you can see the Crankcase pressure under boost. You only need (and want) a gauge that covers your boost pressure ... ~10lbs
You should see very little if any crankcase pressure.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
#37
-Enjoy
fh : )_~
-Enjoy
fh : )_~
#38
Ok UPDATE ! Need some more advise...... well I have figured out several things.. I forgot that i had changed cdr's .. 1st time oil blew out i had put a hose in the cdr down to the ground thus not eliminating the cdr.. 2nd time it blew out i had just pressurewashed it and the cdr got water in it.. i changed back to an old one along the road and made it home.. ive recapped everything over last few days and realized this.. Festus I took your advise today and rigged up a gauge on the dipstick--- barely1 psi in crankcase at about 4 + psi boost so my rings have got to be good... NOW I just got the turbo off and looked down the return hole (old NA cdr hole) and it is almost full of oil about 1/8 inch below rim... ??? i know i didnt have drain holes punched but should it be that high??? and my grommet tore in half and bottm half is in pan out of reach.. would i have to worry about the rest of that grommet getting down below v-pan if i cant fish it out???
#39
this is the valley pan from a 94 factory turbo 7.3, notice the drains on the side, pretty high up.
not sure if the NA pan had the 2 bottom holes but the more holes the better.
it can be a PITA to find another grommet and if your gasket is leaking might just be better off replacing it and staring off with holes punched/drilled in the bottom from the get go
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=994b4356.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/994b4356.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=6546314b.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/6546314b.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&current=68394c12.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/68394c12.jpg" border="0" alt="Uploaded from the Photobucket iPhone App"></a>
#40
Well for anyone reading this thread Ive gotten alot of learning experience from all this and have some things to pass on as to what can happen when you dont punch the holes out for the oil return... all these problems could have been avoided had i punched them... the reason it did not leak for the first 120 miles and that little 10 mile drive is because a piece of the grommet (I had forgot about) that got broke while removing the cdr was floating around to begin with then later it was getting stuck in one of the small vapor holes in the valley pan leading to even more restriction and thus backing up the oil and blowing it out .. and blowing it out at a high rate ! Over the weekend i got turbo off and got holes punched and all back together everything lined up probably better than first time... she runs great and Im pretty lucky i didnt rupture anything up top... got all the exhaust sealed up and got 7 psi and about 750 egts with a light black puff between shifts ... thank the Lord ! I can rest easy now!
#43
It was the exhaust leaks and at the snail.... the uppipe where the crossover bolts and at the bottom of the snail at the gasket had blowed out... what I did there was take a ziptie and compress the snail seal till i got it all the way tight ... my breather gasket is what i used and it was stretched out a little but the ziptie deal worked !! I hit 7 1/5 psi this morning pulling the camper... i couldnt be happier on how much difference this turbo made on my motor.... Ive got some crankcase gases leaking from front of valley pan now and didnt before but at least it aint oil ... I can deal with it and fix it later. Are you having issues like I did?
#44
#45
