electrical system problem please help
Old Mar 4, 2012 | 02:52 PM
bedrock2004f150's Avatar
bedrock2004f150
I have a 2004 f150 4.6 supercrew. I was changing the plugs and un pluged the pcm with the battery still connected. now the truck will die and have no power at all. no codes, battery and ait good.
Old Mar 4, 2012 | 02:57 PM
Franklin2's Avatar
Franklin2
Take the battery off for a minute or so and then stick it back on. If it acts the same, and you still have no codes, drive it for a couple of days and see if it comes back around. These computers "learn" the sensors on your particular engine, and though I haven't heard of a case as drastic as yours sounds, once you take the power off it loses the learned info and it takes awhile to re-learn. It's usually a little bit of a rough idle, maybe a stall once or twice, and maybe a little power difference. See what happens after you drive it a couple of times.
bedrock2004f150
alt is good. after 5 to 10 min it started with no problem
Old Mar 4, 2012 | 03:00 PM
bedrock2004f150
thanks will try that
Draconwolff
2009 - 2014 F150
Aug 27, 2017 08:44 AM
35l911
1983 - 2012 Ranger & B-Series
Sep 14, 2010 08:58 PM
johnnycool
2004 - 2008 F150
31
Feb 21, 2007 04:43 PM
jsim308ons
Apr 12, 2005 08:39 AM
rbachmann
1978 - 1996 Big Bronco
Oct 18, 2004 02:41 PM
