Cross Threaded injectors
Old Mar 4, 2012 | 09:02 AM
Kentwa's Avatar
Kentwa
I believe I may have cross threaded one of my injectors haven't removed it yet. I was thinking I would find a die first. I was checking an old injected for thread size with my calipers and it appears to me the threads on the end where you screw the fuel lines on is a 12X1.75 metric thread can anyone confirm that? thanks for the help
Old Mar 4, 2012 | 09:40 AM
whiteboyslo's Avatar
whiteboyslo
So it's the end where the line hooks up that you think is messed up, right? Easier/better solution may be to install a new injector. People usually recommend doing the whole set, but if the others are in good shape, you might be ok. Of course, this assumes it's the threads on the injector that are boogered and not the ones on the line.
My guess on the thread size is that it'll be a pipe thread size, but I'll defer that to more knowledgeable members.
Mike
Old Mar 4, 2012 | 09:51 AM
Kentwa's Avatar
Kentwa
Yea the injectors are brand new so just buying another and replacing it is an easy option but I'm not normally use to do things the easy way. I thought I might fish someone out to chime in who has been there done that I'm sure my stupidity is not all that unique
Old Mar 4, 2012 | 10:08 AM
kb1jid's Avatar
kb1jid
Just checked one of mine and Iam coming up with 1/2- 20NF with a die
Old Mar 4, 2012 | 10:38 AM
eatont9999's Avatar
eatont9999
Bolt sizer says 12mm and 1.25mm thread pitch. You may be better off replacing the injector but if yours are old, the pop pressure won't match and the timing will be off on that cylinder.
I had the same problem as you and I just replaced the injector with another new one.
Old Mar 4, 2012 | 10:47 AM
Kentwa's Avatar
Kentwa
Awesome thank you the injectors are new Delphi's I was replacing them and I was tired and cranky and the one under the Turbo was giving me trouble instead of taking a break I tried to force it and well lesson learned at least until the next time
Old Mar 4, 2012 | 11:44 AM
tecgod13's Avatar
tecgod13
One thing people with cross-threaded injectors could do, is swap the top half of the injector body with an old, but good piece.
Granted this requires you to have a pop tester and some shims to properly set the pressure, but its easy to disassemble an injector, and the wear items are the nozzle and pintle in the bottom half of the injector which would all stay in bottom half of the injector body (all new from the new cross-threaded injector).
I hope that makes sense...
Old Mar 4, 2012 | 11:51 AM
Kentwa's Avatar
Kentwa
It makes sense to me but still over my head as a novice, I'm hoping to be able to resolve this with my own little pee brain but thats good info all the same. I think I will try running a die over the thread and move it to the front so if it doesn't work it will be easier to access. Do you think I have a shot at getting lucky on this simple solution :-)
Old Mar 4, 2012 | 03:45 PM
eatont9999's Avatar
eatont9999
Spot on, tecgod13. That is the best way to fix and save good injector parts.
Kentwa, don't get rid of the cross-threaded injector. Give it to Russ or someone who can rebuild injectors and they can use the nozzle, pintle, sping and shims to build a good injector. I am hanging onto my injector so I can rebuild it when I build a pop tester.
Old Mar 5, 2012 | 03:07 AM
artfd's Avatar
artfd
Exclamation
You may have damaged the threads on the flare nut of the fuel line rather than those on the injector itself. In this case the cure would probably mean you buy a new metal fuel line segment for that injector.
Old Mar 5, 2012 | 08:01 AM
Kentwa's Avatar
Kentwa
I sure hope thats not the case that would mean removing the injection pump again cause that fuel line is on the bottom on the pump side and under the turbo on the injector side the worst one to replace it will be better for me if its the injector I screwed up
Old Mar 5, 2012 | 09:23 AM
NMB2's Avatar
NMB2
here is what I'm wondering....
How did you manage to cross thread it so bad, that you can't get it to start the regular threads again?
I have started to cross thread mine more than a few times, and have always been able to just realign and go back into the threads.
Did you just say f-it and crank it down? If that's the case... I personally would just leave it alone until you can get a new injector/line. Probably deal with it on the next Injector swap, because you seem to be looking for the easy way out, and there isn't one if what you're saying is correct.
As for which one stripped.... its the lines that strip. The injector bodies are harder than the line nuts.
Old Mar 5, 2012 | 10:40 AM
artfd's Avatar
artfd
Exclamation
I don't know how having a turbo changes things. On my regular IDI it is far easier to remove all the fuel lines than to remove the injection pump, & then just put them back in reverse order.
Old Mar 5, 2012 | 10:50 AM
Kentwa's Avatar
Kentwa
The turbo is in the way of easy access to the threaded nut on the injector its doable but difficult, the reason for removing the injection pump is because that fuel is one of the lower ones on the I/P do you have some special tool that allows unhooking the lower fuel line nuts from the I/P? I'm getting mixed messeges on this also one person is saying he has stripped his injector threads and just replaced the injector and that the fuel line nut is the hardest. Then last night someone chimed in saying just the opposite
Old Mar 5, 2012 | 11:18 AM
artfd's Avatar
artfd
Exclamation
I don't have turbo. After removing my air cleaner I can access all but the bottom 2 fuel lines easily without special tools, just the usual open end 5/8" wrenches.
I remove the bottom 2 fuel lines after first removing all the top 6 lines and the injection pump inlet line. I have one of those ratcheting combination wrenches - 5/8" size. After unfastening any fuel line from its injector, I can slip the ratcheting box end over that flare nut, then all the way back to the other flare nut at the injection pump end. The box end fits easily over the flare & allows you to quickly (and blindly) loosen that flare nut, with the box end at the correct angle, & then pull that whole fuel line free. This is most helpful for the bottom 2 fuel lines, they face downward & are awkward to get to with open ended wrenches. It is otherwise quite difficult to unfasten these bottom flare nuts properly with an open end wrench.
You do have to note how you extract each fuel line, there is only one way to wiggle & wobble each line into its proper position. I recommend you photograph each line just before you remove it - this will help you remember how to get it back into position.
Others have said it's easier to disconnect the fuel lines from the injectors & then remove the injection pump with the fuel lines still attached to it. I've never tried it.
